ᐅ How do I repair damage to Ikea PLATSA wooden components?
Created on: 13 May 2024 09:17
solvi
I have some Ikea Platsa wooden furniture pieces that have developed some unsightly damage. Specifically, there are minor scratches, chipped corners, and in some places, slightly swollen wood. Since the PLATSA series has a rather special surface treatment, I am unsure how to best repair these wooden parts without the repair spots being clearly visible afterward or damaging the surface. Does anyone have experience with repairing damage specifically on Ikea PLATSA furniture?
I am interested in suitable materials (wood filler, paints, waxes, etc.) as well as helpful repair methods. I especially want the result to be durable and visually consistent. I look forward to your tips and experiences!
flo-Theres
14 May 2024 09:35
todunar schrieb:
My tip: Buy a wood repair marker that matches the color roughly to cover small scratches.
This is a sensible starting point, especially if you want to conceal minor damage. It is important to match the color as closely as possible to the original.
Sometimes it is also worth lightly sanding the surrounding area to help the repair marker adhere better and appear more subtle. However, be careful not to roughen the surface too much, as Platsa often has a rather fine sealant.
sifope
14 May 2024 11:02
solvi schrieb:
I am interested in suitable materials (wood filler, paints, waxes, etc.) as well as helpful methods for the repair.
Before I recommend materials, I need to ask a fundamental question: How important is a perfect, nearly invisible result to you?
If you only want to fix minor damage, a touch-up pen is usually enough. However, if you need to repair larger damaged areas that could affect structural integrity, using a professional wood filler or even replacing parts would be advisable.
This is especially important because Ikea boards often consist of thin MDF or particleboard cores with a veneer, which cannot be repaired like solid wood. If done incorrectly, the repair can end up looking worse than before.
Fitigu
15 May 2024 07:44
sifope schrieb:
If you only want to repair small damages, a repair pen is sufficient.
I agree, but would like to add: For minor paint damage, a clear furniture or lacquer touch-up pen based on acrylic lacquer is also recommended, as it is specifically designed for such surfaces.
- After application, it should be gently sanded with very fine sandpaper (grit > 400).
- Then carefully polished or finished with furniture wax to protect the surface.
This results in a durable and discreet repair on PLATSA wood components.
BOMILAN
15 May 2024 11:27
I have had good experiences with an acrylic paint pen that matches the color. After drying, sealing with furniture wax creates a very natural look. For larger scratches, first fill with putty, then paint.
