ᐅ How do I fix a loose door handle on Ikea Metod cabinets?
Created on: 20 Feb 2020 19:45
beratfi55
beratfi55
20 Feb 2020 19:45
Hello everyone, I have an issue with one of the door handles on my Ikea Metod kitchen cabinets. The handle has become loose and keeps turning whenever I open or close the door. It’s the classic handle that’s attached to the door with a single screw from the inside. I suspect that either the screw no longer holds properly or the wood of the door panel might have worn out a bit. I’m looking for a reliable way to secure the handle firmly and permanently without having to replace the entire handle or the door itself. Has anyone experienced this problem before? Are there any special tricks or tools to tighten the screw again? A repair guide or tips on additional materials to use would be very helpful. Thanks in advance for your support!
Josan
20 Feb 2020 20:22
Hello beratfi55,
First of all, thank you for your detailed question – it really helps to better understand the issue. Regarding the loose door handle on Ikea Metod cabinets, there are actually several solutions, which I’d like to summarize clearly for you:
- First, check the screw holding the handle: it is usually screwed in from the inside of the door. Often, the screw loosens simply from frequent use. Try tightening it with a suitable screwdriver first.
- If the screw no longer provides resistance because the hole in the wood has worn out, you can try the following:
- Press small wood chips or wood glue with a toothpick into the hole, then screw the screw back in. This improves grip and fills the cavity.
- Alternatively, special wood filler or small wooden dowels can be inserted into the hole before screwing.
- If the handle itself is damaged or warped, it is usually worth replacing it, but this doesn’t seem to be the case for you.
- A common mistake is overtightening the screw, which can damage the thread in the material, so it’s better to adjust it carefully.
If you have more details, like the type of screw or if the hole is very frayed, I can assist you further. Good luck with the repair!
gipifa
21 Feb 2020 07:39
Josan schrieb:
- Push small wood chips or wood glue into the hole with a toothpick, then screw the screw back in. This provides better grip and fills the cavity.
That's exactly how I've done it too, works great! It’s really frustrating when a cheap handle is loose, but you can fix it well without much effort! 😊
A little tip from me: also make sure the screw isn’t too short. I once used a longer one, which grips better inside the door—it costs almost nothing and provides a much better hold.
Good luck, you’ll manage!
KUDAISY
22 Feb 2020 11:17
Hello beratfi55 and everyone else dealing with loose door handles on Ikea Metod cabinets,
I would like to add a small step-by-step guide to help you firmly reattach your handles permanently:
1. Loosen the screw and remove the handle.
2. Carefully inspect the hole in the door panel: If the hole is too large or worn out, gently sand the edges and remove any loose wood debris.
3. Have wood glue and wood shavings or small wooden dowels (4-5mm (0.16-0.20 inches)) ready.
4. For slightly worn holes:
- Apply some wood glue into the hole.
- Insert small wood shavings or a cut-to-size dowel.
- Press lightly and wait until the glue thickens slightly (about 10-15 minutes).
5. Screw the screw back in, but avoid overtightening, as the wood could tear out again.
6. If the hole is really large, a bigger dowel might be necessary. In that case, the hole needs to be enlarged accordingly to fit the dowel precisely.
7. Finally, reattach the handle and tighten the screw.
Common mistakes that cause the handle to loosen again:
- Screwing too loosely or too tightly
- Using no suitable dowel or reinforcement inside the wood
- Using a damaged screw
I have personally fixed several loose handles using this method without having to order expensive replacement parts. With poor quality wood in the door panel, reinforcing from the inside behind the door can sometimes be a more durable solution.
I hope this helps!
