ᐅ How can I repair a broken IKEA Metod cabinet door myself?
Created on: 23 Jul 2022 08:37
Lolesan
Lolesan
23 Jul 2022 08:37
I recently started having an issue with one of the doors on my IKEA Metod kitchen cabinet. It no longer fits properly, doesn’t close flush, and noticeably wobbles when opening and closing. The hinges aren’t completely loose, but I suspect that either the fastening on the door or inside the cabinet frame is damaged or has come loose.
Since I don’t want to buy and install a new door right away, I would like to know how to repair a broken Metod cabinet door myself. What tools and replacement parts are needed? Are there any proven tips for stabilizing or replacing hinges or fasteners?
Maybe someone here has experience with this exact problem and can describe the procedure in detail—preferably step by step, including how to diagnose the issue.
Thanks in advance for your advice!
Hector
23 Jul 2022 09:51
Lolesan schrieb:
The hinges are not completely loose, but I suspect that either the attachment to the door or the cabinet frame is damaged or loosened.
That’s an interesting point. Before starting any repairs, it’s important to carefully identify where the weak spot is.
Often, it’s not just loose screws but also the wooden inserts holding the screws that are damaged or worn out. In those cases, simply tightening the screws won’t be enough.
My question would be: Have you checked all the screws and inspected whether the threaded holes are still intact? If the holes are stripped, you can address this with special wood repair kits or wooden dowels.
How exactly does the door wobble? Does the wobbling occur at the hinges, or is the issue more related to the door itself?
Ianlau
23 Jul 2022 10:48
Hector schrieb:
If the holes are stripped, you can fix them using special wood repair kits or wooden dowels.
Exactly, if the screw holes are worn out, that is the first step toward proper repair.
I would recommend removing the entire cabinet door before starting the repair. Especially with IKEA Metod doors, the hinges can usually be detached easily with a small lever motion. This way, you can access all the screws better and avoid damage while working.
Then check the damaged areas: Is it just the screws, or is the hinge itself loose?
- For stripped holes, wood filler or wooden dowels help restore stability.
- Sometimes a full hinge replacement is advisable if the hinge is bent or damaged.
I have had good experience with a simple wood repair kit from the hardware store, including wood putty and matching dowels.
Important: After applying the repair material, be sure to let it dry thoroughly before reinstalling and applying any load.
BELLA34
23 Jul 2022 11:13
Remove the door, check the hinges, and tighten all screws. If the holes are damaged, fill them with wood filler or dowels, and refasten after drying. Replace hinges if necessary.
dijan
23 Jul 2022 12:06
Lolesan schrieb:
The hinges are not completely loose, but I suspect that either the attachment to the door or to the cabinet frame is damaged or loosened.
Looks like someone got caught up in the door drama 😅. But seriously: hinges from IKEA can be tricky because it comes down to screws being tightened to the exact millimeter.
My advice: turn this into a small DIY project. Grab a small screwdriver, maybe a wood repair kit, and get to work. A bit of wood glue on a wooden dowel, insert it, reattach the door – done.
If the door still wobbles when closing, a bit of adjustment on the adjustable hinges often helps. You can make small corrections without taking everything apart.
koduga
23 Jul 2022 16:27
I can totally understand how frustrating it can be to deal with a wobbly door. I had a similar issue once with my Metod kitchen.
I would recommend carefully identifying the cause of the problem. Sometimes it’s not the hinges, but the plastic clip that holds the door.
If you’re unsure, try gently removing the door and then take a close look at everything. Even a tiny micro-crack near the mounting area can cause significant issues.
Stay calm, it will get fixed. And feel free to ask if you need any help.
