ᐅ How do I remove Ikea Metod fronts from older models?
Created on: 6 Apr 2018 09:34
pelo0
pelo0
6 Apr 2018 09:34
Hello everyone, I am currently facing the issue of wanting to remove Ikea Metod fronts from older models but am not exactly sure how to proceed. My fronts are several years old, probably from one of the first Metod series, and seem to be attached differently than the newer versions. I am aware that some models still use different clips or screw mechanisms. I would appreciate a detailed guide on the necessary steps, what to watch out for (e.g., specific types of tools, carefully releasing clips), and whether there are differences between the older and newer models that are relevant during removal. Are there any special tips for detaching the fronts from the hinges without damaging them? I would also like to know what to consider when reattaching them later to ensure everything fits properly and remains stable. Thank you in advance for your help!
PLOMA
6 Apr 2018 11:12
Hello pelo0, your question is very well formulated, as it addresses the topic with the necessary details. When removing Ikea Metod fronts on older models, there are indeed some particularities. Basically, the older models mainly differ in the way they are mounted: the fronts on the older Metod systems are usually attached with so-called clip hinges, which can be unlocked by gently pressing a lever. The weak point with these older versions is that the clips often become brittle or rusted, making removal more difficult. I recommend using a small flathead screwdriver to gently pry the clips if needed. Proceed as follows:
- First, open the door at an angle of about 45 degrees.
- Carefully push the release lever (usually on the inside of the hinge) backward.
- At the same time, pull the door lightly outward from the fixture.
- If the clips are too tight, gently use the screwdriver to leverage, but be very careful to avoid deformation.
It is also important not to twist the fittings during removal, as this can change their adjustability. A common problem I see is twisted hinges after removal, especially if the doors have been taken off and put back on multiple times.
pelo0 schrieb:
I know that some models still use other clips or screw mechanisms.
Exactly, on very old versions there can also be the so-called "rotating clip fastener," which requires a different release – in this case, you should gently push the clip to the side and then remove the door.
Also note that some fronts were additionally fastened with screws, especially if they were modified or reinforced afterwards.
For reinstallation, I recommend checking carefully for the proper clicking sound of the clips and aligning the doors well, as small misalignments can later cause problems when closing.
If you like, you can let me know which exact hinge types are installed on your fronts, and then I can give you more precise advice.
hauklo
6 Apr 2018 14:57
pelo0 schrieb:
I would like a detailed guide on the necessary steps, what to watch out for (e.g., specific types of tools, carefully releasing clips), and whether there are differences between the older and newer models that are relevant for removal.
In summary, older Ikea Metod fronts generally use clip hinge systems that can be opened via release tabs. Procedure:
- Open the door and hold it at a 45-degree angle
- Push the release lever backward by hand or with a small tool (e.g., flathead screwdriver)
- Gently pull off the front without applying too much force on the hinges
Regarding tool choice: a small screwdriver is sufficient, but be careful not to scratch the finish or bend the hinges when inserting it.
Differences with newer models mainly involve the shape of the clips and possibly additional screws, which were sometimes used on older fronts. It is advisable to check before starting.
Do not use force, as the clips tend to break. The system is designed to be modular, so removal is relatively simple, but caution is needed, especially with older and potentially brittle components.
Brian
7 Apr 2018 08:43
Hello pelo0, I’d like to add that when removing older Ikea Metod fronts, it is often helpful to slightly loosen the hinges beforehand. This relieves tension and makes it easier to take off the doors. Make sure to check all screws around the hinges and loosen them if necessary.
Another tip is to gently pull the doors outward and then slightly tilt them upward if the standard release mechanism doesn’t work. The older the model, the more varied the fastening systems can be – often there are small modifications made by previous owners.
Regarding tools, you really only need a small flathead screwdriver and possibly a Phillips screwdriver if screws are present. The plastic clips are delicate, so it’s best to work carefully rather than using force.
When you have unhooked the door, it’s best to set it aside carefully, for example on a soft cloth, to avoid damage to the finish.
If any questions arise during reinstallation: the hinges need to be snapped firmly into place, which can sometimes be a bit fiddly if the clips are older. Please let me know if you need more detailed instructions or tips on adjustments.
