ᐅ How do I install IKEA Metod cabinet doors for a soft-close function?
Created on: 5 May 2024 14:03
erolronHello everyone,
I recently installed Ikea Metod kitchen fronts and have noticed that the doors close quite loudly. My question is very specific: How can I mount or retrofit the Ikea Metod doors to achieve a soft-close function?
I’m not just looking to replace the dampers, if possible. Maybe there are also tricks related to how the doors themselves are attached or special hinges I can use?
I look forward to practical tips and real experiences specifically with Metod doors. Thanks in advance!
Here is a brief overview of how to properly install Metod doors for a quiet closing function:
- Step 1: Check which hinges are currently installed. Metod usually uses clip-on hinges that can easily be upgraded to soft-close.
- Step 2: If soft-close hinges are already installed, inspect the screws and adjustments. Sometimes loose hinges cause loud noises.
- Step 3: Hinges should fit snugly without play, but not be too tight to avoid material stress.
- Step 4: If needed, add small felt or rubber buffers at the door surface or inside the cabinet at contact points to reduce rattling.
Common issue: Doors that are not mounted at right angles cause misalignment and noisy closing.
PeoDaniel5 May 2024 16:44Erolron, I can relate to your situation well; the loud closing noise with Ikea Metod is a common issue. In addition to the tips you’ve already received:
Make sure the doors are properly aligned. Even small misalignments during installation can not only cause noise but also lead to mechanical wear over time.
If you’ve already checked that, try lubricating the existing hinges – some hinges can become a bit creaky over time.
Some users also report that attaching damping strips designed specifically for furniture doors afterward can noticeably reduce closing noises.
Keep at it; it’s worth it!
Hey, here’s a bit of enthusiasm on the topic! 😊
I recently retrofitted the Metod doors with the Ikea soft-close hinges – an absolute game changer. The closing now feels much more high-quality and is almost silent!
If you have some DIY skills: the installation is easier than you might think. Just unscrew the old hinges, click in the new ones, adjust them a bit, and that’s it.
Good luck – it’s really enjoyable when the kitchen doors close so quietly now!
