ᐅ How can I protect Ikea Pax wardrobes from scratches?
Created on: 24 Jul 2020 18:27
Hugoja
Hugoja
24 Jul 2020 18:27
Hello everyone, I recently bought an IKEA Pax wardrobe, but I’m quite concerned about potential wear and tear, especially scratches that can easily occur with everyday use. Since the material is primarily a melamine-coated surface, I’m wondering how to best protect this wardrobe from scratches without having to resort to very expensive protective films or complicated solutions.
I’m therefore looking for practical yet durable methods or tips to keep my Pax wardrobe in the best possible condition. In particular, I’m interested in the role of covering or protective films, whether regular waxing or treatment with special care products is advisable, and if there are any construction-related options, such as spacers or edge protectors, that could improve durability.
It would also be great if you could share your experiences with typical wear on such wardrobes and offer advice on how to prevent scratches right from the time of purchase or installation, to minimize the risk as much as possible. Thanks in advance for any helpful answers!
Lilygla
24 Jul 2020 22:56
Hello Hugoja,
first of all, a very well-structured post! Your concerns are completely understandable because with cabinets like the IKEA Pax that have melamine-coated surfaces, the risk of scratches due to the relatively thin protective layer is definitely present.
One strategy that I personally use and can recommend is systematically preventing the main causes of mechanical abrasion:
- Edge protection on corners and edges: There are self-adhesive plastic or rubber edging strips that you can apply to the most vulnerable edges. These prevent direct contact with sharp objects or furniture.
- Protective films made of PET or vinyl: It is important to choose a film that is suitable for the furniture material. Not every film adheres well to melamine-coated surfaces, and some leave residues when removed. A matte, scratch-resistant PET film is a good solution that can also be nearly invisible.
- Care products and waxes: I recommend using products specifically designed for melamine-coated furniture, as the wrong waxes can quickly become streaky or damage the surface. Examples include beeswax-based waxes or special water-based furniture polishes.
Very important: avoid aggressive cleaners or alcohol, as these can damage the protective film.
Regarding spacers: if you often place this wardrobe against a wall, it is worthwhile to attach soft felt pads to the back to prevent the surface from scratching when sliding it.
I hope this helps! If you provide more details about how you use it or the environment, more specialized suggestions can be made.
Donar34
25 Jul 2020 09:33
Lilygla schrieb:
It is essential to choose a protective film that matches the furniture material.
This is an important detail I want to address precisely.
IKEA Pax is made of particleboard with a melamine-coated surface, which is relatively scratch-resistant but not indestructible. Protective films should have the following properties:
- Thin and highly flexible to conform well to corners
- Breathability to prevent moisture buildup that could otherwise warp the material
- Good adhesion without aggressive adhesives that leave residue or damage the surface
Additionally, careful cleaning of the surface before application is crucial; otherwise, dust or grease will cause the protective film to peel off over time.
If a permanent protective solution is desired, I recommend a matte film with anti-scratch properties. This can be applied nearly invisibly, especially on visible surfaces like doors. For edges, protective profiles made of transparent plastic or soft rubber are recommended.
For maintenance, neutral cleaning agents that leave no residue are advisable. Occasional wiping with a slightly damp microfiber cloth is usually sufficient.
Regarding structural measures: spacers such as felt pads are useful if the cabinet is frequently moved or placed in tight spaces. This helps prevent mechanical damage from scratches caused by other furniture or walls.
Summary:
- Thorough cleaning before applying protective films
- Selection of suitable films (PET or vinyl, matte) with appropriate adhesive technology
- Edge protection profiles for corners
- Felt or rubber protection on the back
- Neutral and gentle cleaning routine
These measures significantly reduce the risk of scratches on the Pax cabinet.
rimole
26 Jul 2020 07:41
I take a pragmatic approach: felt pads on all contact points with the floor or furniture. For sensitive surfaces like the Pax, scratch-resistant protective films also help, but only if they are well-fitted and applied carefully.
Regular maintenance with a mild furniture cleaner and avoiding sharp objects nearby is usually enough to prevent major scratches.
