ᐅ How can I protect IKEA Metod kitchen cabinets from scratches during assembly?
Created on: 22 Mar 2016 08:37
brandon
brandon
22 Mar 2016 08:37
Hello everyone, I am planning to assemble an IKEA Metod kitchen soon and would like to know the best way to protect the kitchen cabinets from scratches during assembly. Although the surface of the fronts is quite durable, I definitely want to avoid any visible scratches or dents while handling and installing – whether caused by tools, moving the panels on the floor, or bumping doors and cabinet carcasses.
I am particularly interested in practical tips for preparing the workspace, handling the individual parts, and any protective materials you would recommend. Are there any special techniques I should keep in mind during assembly to maintain the valuable appearance of the Metod kitchen units?
Thanks in advance for your helpful advice!
Katau
22 Mar 2016 09:24
Hello Brandon, your question is very well formulated and the concern is completely understandable. Scratches during the installation of kitchen cabinets are frustrating, but with some preparation, they can be easily avoided. First, I recommend clearing and cleaning the assembly area with enough space. It is best to lay down blankets, thick cardboard, or special installation sheets on the floor before placing the kitchen cabinets on them. This prevents scratches caused by small stones or uneven surfaces. Second, when moving doors and cabinet boxes, do not simply place them on their backs. Here, cut foam pads or folded towels help to avoid direct contact between the surfaces and the floor. Third, I advise using all screws and tools with care, and avoid positioning screwdrivers or cordless drills close to the edges of the fronts to prevent dents or scratches. One more tip: lift individual elements with two people whenever possible instead of dragging them over the floor; this greatly reduces the risk of damage to the edges. I hope these points are helpful already!
pautanner
22 Mar 2016 11:46
Hey Brandon, a little tip from me with a wink: keep the packaging material! The plastic wrap and cardboard that the Metod parts come in are perfect for temporary protection on your floor or even for covering surfaces while you work. Nothing is worse than accidentally denting a door during assembly because a piece of furniture was dragged across a stone floor on the way to the next screw. Better to play the helpful neighbor and lift the piece briefly or place the furniture on old sweaters—anything is better than having no protection on the floor. 😄 Also, be careful not to overtighten the screw holes; the fronts are sturdy but not indestructible. Good luck with the assembly and don’t get discouraged, it’s really fun!
brandon
22 Mar 2016 14:02
Katau schrieb:
It’s best to lay down ceiling panels, thick cardboard, or special assembly films on the floor before placing the kitchen cabinets on them.
I’m particularly interested in these assembly films. Are there specific types or materials that work especially well with Metod kitchens? I want to avoid anything that slips or doesn’t provide cushioning.
pautanner schrieb:
Keep the packaging material! The packaging film and cartons that the Metod parts come in are great for temporary protection on your floor or even for covering things,
That’s true, I’ll definitely do that—I hadn’t thought of it until now. I’m just wondering how to best handle transporting the heavy cabinets without risking scratches—do you have any tips for managing their size and weight?
hauklo
23 Mar 2016 07:18
Regarding the transportation and handling of large cabinets during assembly, I recommend the following: Always use soft protective materials such as felt pads or thick blankets to prevent dents and pressure marks on the surfaces. If the cabinets are placed on the floor, this should only be done on level and clean surfaces to avoid abrasion. Always work in pairs when carrying and moving the furniture, and lift not by the handles but at structurally strong points. Always handle tools carefully, and pre-mark sensitive areas (such as edges) with red indicators to help protect these spots. For assembly films, I recommend polyethylene sheets with a slightly adhesive surface that prevents slipping but still provides good cushioning for the furniture. Make sure that no small particles are trapped between the film and the furniture piece.
Teonon
23 Mar 2016 13:53
Oh yes, assembling a Metod kitchen is quite an adventure! But don’t worry, with the right tips everything will stay scratch-free. Here are my favorite tips:
- Always wear gloves, especially when handling heavy parts – this gives you better grip and prevents surfaces from getting damaged by fingerprints or dirt.
- Never place kitchen parts on the front side; it’s better to lay them on the back, which is usually less sensitive.
- Small foam strips or felt pads on corners and edges can work wonders.
- The more people helping with the assembly, the easier it is to avoid accidental bumps or scratches.
Have fun! In the end, the kitchen will look even better shining without any damage. You’ve got this! 🙂
