ᐅ How can I protect IKEA Hemnes furniture from scratches caused by pets?
Created on: 26 Apr 2016 09:17
renmi
renmi
26 Apr 2016 09:17
Hello everyone, I have some IKEA Hemnes furniture at home, which I really like for its style and sustainability. However, I have the problem that my two cats often scratch the surfaces, especially on doors and drawer fronts. I am therefore looking for effective methods or products to protect the Hemnes furniture from scratches caused by cats or other pets, without damaging the furniture material or its appearance. Does anyone have experience with protective films, special coatings, furniture covers, or other preventive measures? I am particularly interested in recommended alternatives that can be easily removed if the situation changes. I would appreciate any well-founded tips on how to best preserve the delicate surfaces, especially on Hemnes furniture made from pine or MDF with real wood veneer.
edisondan
26 Apr 2016 10:43
Regarding the question of how to effectively protect IKEA Hemnes furniture from scratches caused by pets, I recommend the following approach:
- Use special clear furniture films made of polyurethane or PVC that are scratch-resistant and have minimal visual impact. These can be cut to size and removed without leaving any residue.
- Alternatively, matte furniture paints with a scratch-resistant finish, preferably water-based, can be applied after thorough cleaning. However, this requires more effort and is an irreversible measure.
- Placing cat toys and scratching posts near the furniture can help redirect scratching activity to other surfaces.
It is important to test a small area beforehand to ensure that the material of the films or paint is compatible with the surface, as Hemnes doors are usually made of painted wood or veneered MDF. Overall, clear adhesive protective films offer the best combination of protection and maintaining the appearance.
benonon
26 Apr 2016 11:27
When considering how to protect IKEA Hemnes furniture from pet scratches, it is important to first examine the surface materials of the furniture more closely. Hemnes is known for its combination of pine wood and partially veneered MDF, which generally has a delicate finish.
If scratches are caused by cats or other small pets, this often results from their claws, which can leave visible marks on painted surfaces even during normal behavior. Here is a structured approach:
- Step 1: Identify the most common contact areas. Is it the front, the tabletop, or hidden corners that are frequently scratched?
- Step 2: Acquire transparent protective films, preferably made of polyurethane, as these offer high scratch resistance. It is important to cut them precisely to the edges of the furniture to avoid bubble formation.
- Step 3: Alternatively, apply scratch-resistant coatings, such as water-based acrylic varnishes, which dry with relatively low odor and do not yellow over time. Multiple layers are beneficial here but involve increased effort.
- Step 4: Encourage positive pet behavior by providing scratching posts or cat furniture made from sisal or other durable materials.
- Step 5: Maintain the furniture with suitable oils or care waxes to make the wood more resistant to surface damage.
It would also be useful to know whether the scratches occur during playful behavior or from boredom, in order to tailor the best strategy.
V
van_pe
26 Apr 2016 12:05
edisondan schrieb:
Use of special clear furniture films made of polyurethane or PVC that are scratch-resistant and have little visual impact.
I can confirm that myself—I have films on a Hemnes wardrobe, and they provide good protection against scratches. It is important to apply the film properly and without bubbles.
NAU34
27 Apr 2016 08:19
I think using transparent protective films on Hemnes furniture is a really stylish solution. This way, the character of the wood is preserved, and the cats don’t just walk all over it freely.
It also helps a lot if you set up proper scratching areas for your two indoor cats—whether it’s sisal scratching posts or cardboard boxes that they love!
All joking aside: Sometimes a little “redirection” is the best approach. The furniture likes to be well cared for, and the cats need their claws :-)
Life can be better for everyone involved when you find the right balance!
benonon
27 Apr 2016 12:34
renmi schrieb:
I am therefore looking for effective methods or products to protect the Hemnes furniture from scratches caused by cats or other pets, without damaging the furniture material or affecting its appearance.
This is the core challenge. To avoid altering the appearance, you should use only clear protective films that are either fully transparent or very thin and matte, so they remain barely visible. Another option could be applying furniture wax, especially formulated for pine wood, which makes the surface somewhat more resistant.
NAU34 schrieb:
Sometimes a bit of "redirection" is simply the best approach.
I completely agree and would add that behavioral conditioning of the cats should be given more priority. This means targeted training to avoid scratching the furniture and gradually getting them used to scratching posts.
Important: If paint or film is used, make sure the chemical ingredients are safe and not harmful to animals.
What about the current location of your furniture? Is it frequently used or less accessed? This significantly affects the choice of protective measures.
