ᐅ How can I protect Ikea Brimnes furniture from moisture damage?
Created on: 8 Dec 2022 09:37
O
Oktay58Hello everyone, I recently purchased an Ikea Brimnes piece of furniture and plan to use it in a room that can occasionally get a bit damp, such as near an open window or sometimes in the kitchen. My question is: What effective methods or measures are there to protect the Brimnes from moisture damage? I would like to know if there are special sealants, protective coatings, or structural measures that have proven effective to keep the furniture durable and prevent swelling or surface deterioration. Thanks in advance for all tips and experiences!
Basically, the Ikea Brimnes is made of veneered particleboard or MDF, which makes it sensitive to moisture. To protect the furniture piece long-term, I recommend the following measures: - Treat surfaces with a thin layer of special wood sealer or water-repellent clear lacquer, applying with a cloth or brush. - Protect especially vulnerable edges by additional sealing or, if possible, with edge protectors made of plastic or metal. - For the placement area: ensure sufficient ventilation and avoid direct exposure to splashing water. - Furniture legs should be placed on feet with spacers to prevent moisture rising from the floor. - In cases of consistently high humidity, I also recommend using a dehumidifier. These routines can help prevent damage such as swelling or delamination.
Hello, I would like to suggest a good approach to protect your Ikea Brimnes from moisture: First, lightly sand the surface to improve the adhesion of the sealant. Then apply at least two thin coats of a water-repellent clear varnish or wood preservative, as multiple thin layers are more effective than one thick layer. It is especially important to treat the edges and backs, as these are often overlooked in IKEA furniture and are particularly vulnerable to moisture. During assembly, make sure the furniture does not stand directly against cold walls and that the floor is dry. If you use it directly in the kitchen, I also recommend placing a protective mat or a slightly raised board under the piece. In summary: 1. Roughen the surface 2. Apply thin layers of sealant 3. Protect the edges 4. Choose the location carefully 5. Control humidity if necessary This will help prevent swelling and keep the furniture in good condition for a long time.
Jensson schrieb:
Edges and backs are especially important because they are often neglected in IKEA furniture and are particularly vulnerable to moisture.That is correct, as the edges in cheaper furniture are often only thinly veneered or not protected at all, which can accelerate swelling. Additionally, I recommend using plastic washers or spacers in heavily used lower areas to raise the furniture off the floor.
te-min schrieb:
Place it in well-ventilated rooms and avoid standing water.This should not be underestimated, as air circulation effectively helps prevent moisture buildup. Without it, furniture remains damp longer and suffers damage.
Finally, one more tip: for especially durable protection, special wood oils can be used. These penetrate the wood and protect against moisture but are usually an additional option alongside surface sealants.
