ᐅ Is the assembly of the IKEA Brimnes furniture also manageable for seniors?
Created on: 12 Apr 2016 13:04
GerdbuDear community,
I am currently considering whether assembling the IKEA Brimnes furniture set is easily manageable for seniors. My main focus is on how easy or difficult the individual components are to handle, how clear the instructions are, and whether any special tools are required that might pose a challenge for older people. Additionally, I am interested in whether the construction itself remains straightforward given the delivered parts, or if there are potential pitfalls that could make assembly harder, especially with reduced strength, limited mobility, or visual impairment.
Does anyone have experience with this, perhaps even in the senior sector, and can provide insights or tips? It would also be helpful to know if it is better for an older person to rely on external help or if the furniture is designed to be assembled alone without risk of mistakes or frustration.
Thank you in advance for your feedback!
Hello Gerdbu! I think Brimnes is great! The instructions are really easy to understand, even if your eyesight isn’t perfect or you’re not as physically fit! You can do it, just take your time and go step by step 🙂 I helped my grandma with the assembly, and it was really fun! Just keep at it, it’s definitely worth it!
Hello Gerdbu,
I have assisted with assembling several IKEA furniture pieces designed for seniors. It is important to sort the parts carefully and not just skim through the instructions. In my opinion, the Brimnes series is fairly straightforward. The manual uses pictures instead of a lot of text, which is especially helpful for those with limited eyesight. The screws are manageable, and the tools are usually easy to handle since it mostly requires just one Allen key. However, assembly can still be tricky when holding panels in place while screwing, particularly when working alone.
My recommendation: If possible, have a second person help, at least with the heavier or larger parts. This significantly reduces strain on joints and physical effort. Another tip is to set up a well-lit workspace and perhaps a quiet environment to avoid stress.
If you have any questions about the process, I’m happy to help!
raKatharin12 Apr 2016 14:29From my experience: Brimnes is not rocket science. The biggest challenge is holding up the larger panels. Otherwise, the instructions are easy to understand. If seniors take their time and work slowly, it goes well.
nikian schrieb:
The number of screws is manageable, and the tools are usually easy to handle since mostly just an Allen wrench is needed.Thank you for this valuable information! Since the size of the screwdriver or Allen wrench often causes difficulties for people with limited hand strength, this actually sounds promising.
raKatharin schrieb:
The biggest problem is holding the larger panels up.Could clamps or support surfaces be used here to avoid having to hold the panels continuously? Or are there any recommendations on how to best stabilize the heavy parts? I would like to prevent seniors from becoming easily overexerted.
Also, I am interested: Are there any known pitfalls or common mistakes that seniors make with this piece of furniture? I could then communicate these precautions in advance.
