ᐅ How do I properly clean IKEA Besta furniture when it is heavily soiled?
Created on: 7 Feb 2019 08:37
JaysonreoJ
Jaysonreo7 Feb 2019 08:37Hello everyone, I hope you can help me. I have some IKEA Besta furniture in my apartment that unfortunately has quite heavy stains on the finish and surface. Especially affected are areas where grease marks and sometimes stubborn dirt have accumulated. Since I don’t want to damage the surface, I’m looking for a cleaning method that is both effective and gentle.
Can anyone give me tips on how to properly and sustainably clean IKEA Besta furniture when it has such heavy soiling? Are there any specific products recommended, or perhaps methods that should definitely be avoided? I’m looking forward to your experiences and advice!
Hello Jaysonreo, I understand how frustrating such stains can be – especially on the smooth surfaces of Besta, they become noticeable quickly.
First of all: Avoid using aggressive abrasive cleaners or solvent-based products that can damage the finish.
My advice: A mixture of warm water and a few drops of mild dish soap usually works wonders. Moisten a soft sponge or microfiber cloth with this solution and gently wipe the surface! For stubborn stains, dampen the cloth briefly with the solution and let it sit on the spot for a few minutes before gently rubbing.
If that doesn’t work, you can try a very diluted vinegar solution – but use it cautiously and not too often! Vinegar can dull the finish over time.
Good luck – and remember: less is often more 😊
Jaysonreo schrieb:
I have some IKEA Besta furniture in my apartment that unfortunately shows quite heavy stains on the paint or surface. The most affected areas are spots where greasy fingerprints and sometimes stubborn dirt have accumulated.Hello Jaysonreo,
that sounds like a real challenge, but with the right approach, you can definitely get your Besta furniture clean again. I recommend the following steps:
- First, wipe the furniture with a soft, damp microfiber cloth to remove loose dirt.
- Then prepare a solution of warm water and a mild, pH-neutral dish detergent.
- Apply this solution with a soft sponge or cloth, then wipe the surface with clean water to avoid any residue.
- For especially tough stains, you can try a mixture of water and isopropyl alcohol (at least 70%), but be sure to test it on an inconspicuous area first.
- Never use abrasive pads or harsh cleaners, as these can permanently damage the paint finish.
Patience is key here – often, gentle repeated cleaning works better than scrubbing hard once.
I hope this helps you out!
Nauman5 schrieb:
A mixture of warm water and a few drops of mild dish soap is often already very effective.Sure, the good old soapy water is an obvious choice. But honestly, is that really enough for heavy stains?
I know furniture that has become really grimy over years of heavy use with various substances – no dishwater will work miracles there. I think it makes sense to also use some mechanical help, even if it’s just a plastic scraper or a soft eraser for painted surfaces.
Of course, without applying pressure, but you shouldn’t overestimate the gentle method. Also: Has anyone here had experience with special furniture cleaners, or is that mostly marketing?
I believe we underestimate how much patience such furniture requires. Water and dish soap alone don’t always do the job.
GALEO4 schrieb:
I think it makes sense to use some mechanical help occasionally, even if it’s just a plastic scraper or a soft eraser for painted surfaces.I agree with that! For me, using an eraser followed by wiping with a damp cloth has proven really effective for removing baked-on stains.
One more tip: Use warm air, like a hairdryer on a low setting, if the spot is stubborn, to soften the dirt a bit before rubbing.
Be careful when drying – avoid direct heat on the paint, as it can cause damage.
All in all: Be patient and take small steps rather than scrubbing aggressively in one go. Paint can handle a lot, but you naturally want to preserve the polished finish.
