ᐅ How can I properly align Ikea BESTA drawers to prevent them from sticking?
Created on: 10 Sep 2022 14:03
O
onfuliHello everyone, I recently purchased the IKEA BESTÅ system and I am facing an issue with the drawers. They often get stuck when opening or closing, which is quite annoying. I have already checked whether the drawers are properly installed, but the problem persists. My question is: How can I align the IKEA BESTÅ drawers correctly to prevent them from sticking? Are there any specific adjustment mechanisms or settings I need to consider? I am especially interested in a step-by-step explanation to make sure I don’t overlook anything. Maybe you also have troubleshooting tips or insights on common issues with this system. Thanks in advance for your help!
The drawers of the IKEA BESTÅ systems do require some adjustment to ensure smooth operation. First, it is important to correctly insert the drawers into the guide rails. These usually have various adjustment screws that allow for fine-tuning of the drawer:
- Height: The adjustment screws on the rail allow vertical alignment of the drawer.
- Depth: Sliding the guide arms forward or backward can optimize the drawer stop.
- Side alignment: Sometimes, slightly shifting the drawer sideways helps prevent it from rubbing against the cabinet side.
The metal or plastic guides should also be clean and free of dust. A few drops of silicone spray can help if the runners are dry. Important: Also check that the cabinet corners are square and level, as misalignment often leads to jamming.
lalutau schrieb:
The important thing is to insert the drawers correctly into the runner rails.This is a crucial point I would like to add: The BESTÅ drawers use a so-called Metabox system, where the drawer sides run on variably mountable runner rails. Proper installation of these rails is essential. Important points are:
- Check that all screws in the runner rails are firmly tightened to avoid any play.
- The rails should be mounted precisely parallel and at a right angle to the cabinet carcass.
- For fine adjustment, use the side screws on the rails to align the drawer perfectly on the horizontal plane.
- In most cases, you can slightly raise or lower the drawer by turning the adjustment points with a Phillips screwdriver.
I also recommend inspecting the runners after pulling out the drawer and lubricating or replacing any plastic rollers in the runners if they are damaged. Without these precautions, the drawer often sticks. Can you describe more precisely whether the sticking occurs right from the start or only after some use?
Nakar33 schrieb:
Could you describe more precisely whether the sticking occurs right from the start or only after some use?The sticking effect is actually present from the very beginning. I took the drawers out of the box and assembled them for the first time. As soon as I inserted them, I immediately noticed that the drawer sticks at the lower part – it feels like the track or the roller bearing is not running smoothly. The drawers are still quite parallel vertically, but there might be some lateral play. I rule out uneven installation of the cabinet since it stands stable and level. I wonder if the tracks are supposed to be pre-oiled or require maintenance?
onfuli schrieb:
I wonder if the drawer slides come pre-lubricated or need maintenance?The IKEA BESTÅ drawer slides are usually delivered without lubrication and work fine without it. However, dust or manufacturing residues can slow down the rollers. My recommendation:
- Remove the drawer and clean the slide rails with a lint-free cloth.
- If needed, apply a small amount of silicone spray or PTFE-based lubricant on the rollers and slide rails. Avoid using oil, as it attracts dirt.
- Check the plastic rollers for cracks. If any roller is damaged, it is best to replace it.
Otherwise, proper alignment of the drawer within the cabinet is the key factor. Especially with BESTÅ, you should fine-tune the height adjustment using the screws on the side panels.
Additionally: When installing the BESTÅ drawers, it is advisable to fully extend the rail from the cabinet first and then slowly slide the drawer in. This makes it easier for the rollers to engage and prevents the guide from shifting. The screws on the inside of the cabinet should also be checked, as they can sometimes loosen slightly, causing a slight tilt that may lead to catching.
