ᐅ How can I prevent IKEA BRIMNES drawers from coming off their tracks?
Created on: 8 Aug 2020 07:12
Kibasar
Hello everyone, I currently have several IKEA Brimnes dressers at home and have increasingly noticed that the drawers sometimes come off their tracks, which is obviously annoying. I am especially interested in how to prevent this from happening permanently. I understand that it might be due to the quality of the drawer slides, but also how the drawers are used or installed.
My specific questions are:
- Are there any special installation or adjustment tips to keep the drawers from coming off the tracks?
- What can be done if a drawer has already come off several times—how can this be properly repaired or adjusted?
- Are there alternative sliding systems or reinforcements that can be fitted to BRIMNES drawers?
I look forward to practical and detailed answers, preferably with advice on common mistakes to avoid.
Ethan
9 Aug 2020 11:45
Hello Kibasar, from my experience, regular maintenance is especially important. The following procedure has worked well for me:
- Fully remove the drawers.
- Carefully clean the slide system, for example with a damp cloth or compressed air, to remove dust and dirt.
- Check the plastic bearings and rollers: are they still round and moving freely?
- If the plastic is already brittle, I recommend replacing them (even though it means an additional investment).
- After cleaning, it is best to use a dry lubricant, such as silicone spray specifically designed for plastic slides.
- Insert the drawer straight and make sure that the rails are perfectly aligned parallel during installation.
If you find that the drawer still frequently comes off despite these measures, adding an additional locking mechanism may help. You can find small plastic clips or metal brackets at hardware stores, which can be mounted inside the dresser to prevent lateral pull-out.
Feel free to ask if you have any further questions – just get in touch.
COLEBAR
9 Aug 2020 16:02
Drawers often come off track because the runners are bent or dirt is blocking their movement. So:
- Align the runners properly
- Clean them
- Avoid overloading
This is usually sufficient.
PAR63
10 Aug 2020 07:14
Ethan schrieb:
If the plastic is already brittle, I recommend replacing it (even if that means an additional investment).
Exactly, that’s a crucial point! Plastic rollers age and lose their elasticity. This is a common problem that causes drawers to come off their tracks without guidance.
I have often received replacement parts from IKEA, as they still provide spare parts for the Brimnes series. Just contact customer service and ask for the drawer slides and rollers. Spending a few euros and a bit of replacement work makes a big difference.
Additionally, drawers should never be pulled out while fully loaded; this puts unnecessary strain on the system and increases the chance of them coming off.
Among other things, this is an effective way to manage the problem!
Danial
10 Aug 2020 09:47
PAR63 schrieb:
The plastic rollers age and lose their elasticity.
Interesting, thanks for the insight! This supports the idea that it is a design weakness.
Although replacement parts offer a short-term fix, the question arises whether it would be better to upgrade the furniture with a more robust sliding mechanism.
Has anyone had experience converting to ball-bearing metal slides? And if so, how complex is the process, or is it reasonably feasible to do this with BRIMNES?
