ᐅ What troubleshooting steps can help with sticking IKEA BRIMNES drawers?
Created on: 18 Feb 2021 09:17
Ren56
Ren56
18 Feb 2021 09:17
Good morning everyone, I have a recurring problem with the drawers of my IKEA Brimnes bed frame: some of the drawers stick when opening or closing, which significantly affects usability. My question is: what systematic troubleshooting steps do you recommend to specifically identify and fix the causes of sticking BRIMNES drawers? I have already checked the rails, but the problem persists. I suspect there could be several possible causes, such as warped wood components, dirt, damaged rollers, or misaligned guides. I would appreciate a step-by-step guide or tips on which potential causes to check and in what order to efficiently narrow down the issue. Thanks in advance for any helpful suggestions!
kauti
18 Feb 2021 10:03
In general, a systematic troubleshooting process in several steps is recommended for sticking BRIMNES drawers:
- First, check if the drawer slides are clean and free of obstructions. Dirt or small debris often cause problems.
- Next, verify the alignment of the slides: Are they mounted parallel and straight?
- Check whether the drawers themselves are warped. This can result from uneven loading or moisture.
- Inspect the mechanism of the rollers or gliders for damage.
- If any defects are found, replace or readjust the affected parts.
It is important to rule out the cause through targeted tests. For example, if the drawer is completely unloaded and the problem improves, the cause often lies with the load or a warped cabinet.
tarju41
18 Feb 2021 11:21
It is best to remove the drawer and thoroughly clean all the tracks. Then reinstall it and check if it slides smoothly. If not, inspect the rollers or glide shoes for damage.
sarlo
18 Feb 2021 12:08
Hello Ren56,
Your approach of systematically ruling out the causes is very good. As an additional tip, make sure that the drawer sits precisely on the slides when inserted. Sometimes it helps to lift the drawer slightly and gently push it in to rule out installation errors. Moisture can also cause the wood to swell, which makes sliding more difficult. If that’s the case, let the drawer dry well. If you want, you can also apply some furniture wax to the runners, which noticeably improves the sliding.
Ren56
18 Feb 2021 15:42
sarlo schrieb:
Sometimes it helps to slightly lift the drawer and gently slide it in to rule out installation errors.
Thanks, that’s an interesting tip. I will check if I can slightly lift the drawers while they are installed.
One more question: If I remove the slides, are there specific points I should pay attention to during reinstallation to avoid misalignment? Honestly, I’m a bit concerned about removing and reinstalling them, as the construction doesn’t seem very sturdy to me.
kauti
18 Feb 2021 17:59
Ren56 schrieb:
If I remove the rails, are there specific points I should pay attention to when reinstalling them to avoid misalignment?
Yes, definitely.
- The rails should always be precisely leveled horizontally; using a spirit level is the best way to ensure this.
- Make sure they are securely and fully fastened with the designated screws to prevent twisting.
- Both sides’ rails must be installed identically so the drawer does not run at an angle.
- Before tightening everything, test-fit the drawer by sliding it in to check the fit.
This will ensure smooth operation later on.
