Hello everyone, I have several Billy bookcases from IKEA, and I've noticed that some of the shelves wobble a bit or sag slightly in the middle. I'm interested in how to permanently prevent Billy shelves from wobbling or sagging. I’m specifically referring to the standard shelves without any additional reinforcements or metal inserts. Does anyone know of proven methods or useful hacks to make the shelves more stable without major modifications to the bookcase? Thanks for your tips!
To precisely prevent sagging, it is important to consider the actual load on the shelves from a physical perspective. The maximum recommended load of about 30 kg on an 80 cm (31.5 inches) wide BILLY shelf is close to the maximum bending strength of the MDF board.
A simple technical adjustment: attaching an additional crosswise strip under the shelf – in the middle – improves load distribution and reduces stress. Additionally, the attachment of the shelf supports should be checked to ensure they are securely anchored in the wall. Wall mounting also increases overall stability. If necessary, you can switch to shelves made of solid wood or plywood instead of standard MDF, as these tend to sag significantly less.
Here is a summary:
This is probably the best DIY solution with minimal effort.
A good option if you prefer to use metal.
This explains technically that the choice of materials makes a difference.
Finally, it is important that the shelf is securely fixed to the wall to prevent wobbling.
Heiner48, if you want, I can also provide a step-by-step guide on installing a central wooden strip. In my experience, this kind of reinforcement is the most effective way to prevent sagging and wobbling.
BARSAN schrieb:
I always use wooden strips and screw them centered under the shelves.
te-min schrieb:
At the hardware store, there are thin metal brackets that can be attached to the underside of the shelf.
Fitigu schrieb:
Reinforcement with a central support [...] Alternatively, a thin plywood panel can be mounted under the MDF shelf.
