ᐅ How can I effectively remove scratches from IKEA Besta surfaces?
Created on: 28 Jul 2017 13:07
jelapau
Hello everyone, I recently assembled an IKEA Besta shelving unit and unfortunately noticed some scratches on the surface finish. Since I don’t want to replace the furniture, I am looking for sustainable methods to remove or at least significantly reduce these scratches. It is important to me that the chosen solution does not damage the surface or worsen its appearance in the long term. Who has experience with removing scratches from Besta surfaces? Which home remedies, care products, or treatments would you recommend that are both truly effective and gentle? Thanks in advance for your tips!
Thank you for all the helpful tips so far!
Most of the scratches are shallow, not deeply etched, but some are quite visible and slightly noticeable to the touch. The surface is melamine-coated, so you’re right, perforating is not an option.
I also want to avoid unpleasant color differences or gloss variations after a repair. Is there a recommended brand or a specific product that has proven effective? Or is it better to simply use a universal furniture repair kit and mix the color and wax yourself?
Additionally, I would be interested to know if anyone has experience with how these repairs hold up over several years. Is a single treatment enough, or does it need to be repeated annually?
To ensure durability and avoid visible differences in color or gloss when repairing melamine-coated surfaces, the following recommendations apply:
- Furniture repair kits from manufacturers such as "effex" or "Brunne" are formulated for durability and offer various shades and waxes that can be well matched in color.
- Repair spots, when applied and maintained correctly, can last several years but may need touch-ups under heavy use (e.g., in households with children).
- It is important to follow the kit’s instructions carefully to ensure the wax layer bonds properly and does not peel prematurely.
Sustainability here refers not only to the repair itself but also to the subsequent care, such as regular gentle cleaning and occasional re-polishing.
A universal repair kit is usually sufficient; individual color adjustments can be made with color pastes or touch-up markers.
jelapau schrieb:
The surface is melamine-coated, you’re right, lochen.That confirms my assessment.
Regarding the durability of the repair: In my experience, for shallow scratches like yours, a single application of repair wax is usually sufficient, provided the surface is not subjected to further mechanical stress during daily use.
If the repaired area needs to be polished again after some time, this is not a major effort but more like a minor touch-up.
One more tip: Always test repair products first on an inconspicuous spot or a sample piece to check the color match and gloss level. This helps avoid unwanted contrasts on the surface.
For me, sustainability means securing preservation with minimal effort and avoiding interventions that cause more harm than good.
