ᐅ After attaching new cabinet handles, the surface of the KALLAX started peeling off – how can this be repaired?
Created on: 2 Jul 2020 10:12
elzar70
Hello everyone, I recently attached new furniture handles to my IKEA KALLAX shelf. Unfortunately, a problem occurred: the surface is peeling off in several places where the screws for the handles are located. The MDF board underneath the veneer seems to be damaged, and I would like to know how to professionally repair this damage so that it is as inconspicuous as possible and remains stable. Has anyone experienced similar issues with KALLAX or similar furniture? What materials or methods have you used to restore or protect the surface? Thanks in advance for your tips!
O
olivernu
2 Jul 2020 17:38
Basically, the filler should be MDF-compatible, meaning it should be slightly flexible and not too hard. Special wood fillers for MDF are recommended because they do not become too brittle.
Additionally, drilling pilot holes with a smaller drill bit before attaching the handles helps prevent cracking. Using washers reduces localized pressure, which is useful.
For painting, a matte acrylic paint or clear furniture lacquer is advisable. This hardens the surface somewhat and protects against further peeling. Important: apply the paint in thin layers and allow it to dry thoroughly between coats.
koduga
3 Jul 2020 09:21
I can really understand the frustration when there are issues with the surface. I had a similar problem with a shelf and solved it like this: After sanding down the damaged areas, I worked with some wood glue and fine sandpaper.
elzar70 schrieb:
Are there any recommendations on how thick or flexible the filler should be?
For my repair, I applied a thin layer and sanded it very smoothly. The best part was that I didn’t feel any stress afterward because the glue remains slightly flexible. Then I carefully primed and painted it. It lasted for several years.
jordanvin
3 Jul 2020 10:17
That’s great that you all have such helpful tips! 🙂 I had no idea before that using washers when screwing handles onto KALLAX is a must.
Elzar70, you can definitely do it! Don’t get frustrated—patience will get it fixed again. Maybe after the repair, you could share what worked best for you. That would surely help others here as well!
leguson
3 Jul 2020 16:46
Brief note on screw selection: Never use wood screws that are too thick in diameter or too long, as this can cause stress and cracks. Small, short screws with a washer are ideal. The filler compound should not create a bond that is too rigid to prevent cracks from forming later.
elzar70
4 Jul 2020 08:53
Thank you all for your many helpful responses! I will try to apply your tips.
Specifically, I will carefully remove the loose film, build up the uneven areas with MDF-compatible filler in thin layers, and sand them smoothly after drying. For the screws, I will get appropriate washers and shorter screws. Finally, I will paint the surface with matte acrylic lacquer to protect it.
I am confident that this approach will stabilize the surface while keeping the handles firmly attached. If anyone has specific product recommendations for filler or lacquer, I would appreciate it! I’ll update again once I’ve finished the repair.
