ᐅ How can I effectively remove scratches from IKEA Besta surfaces?
Created on: 28 Jul 2017 13:07
jelapauHello everyone, I recently assembled an IKEA Besta shelving unit and unfortunately noticed some scratches on the surface finish. Since I don’t want to replace the furniture, I am looking for sustainable methods to remove or at least significantly reduce these scratches. It is important to me that the chosen solution does not damage the surface or worsen its appearance in the long term. Who has experience with removing scratches from Besta surfaces? Which home remedies, care products, or treatments would you recommend that are both truly effective and gentle? Thanks in advance for your tips!
Hello jelapau,
First of all, it’s great that you want to treat the surface carefully. IKEA Besta usually consists of melamine-coated panels or painted surfaces, which are durable but not indestructible.
For sustainably removing or concealing scratches, I recommend the following approach:
- Light scratches: Often, using a microfiber cloth and some furniture polish (e.g., plant-based wax) can already improve the appearance.
- Deeper scratches: A special furniture repair pen or wax filler in a matching color is often suitable, as these fill in the scratch.
- Avoid aggressive solvents, as they can damage the coating.
Home remedies like olive oil can help temporarily, mainly for enhancing appearance and care rather than actual repair.
Feel free to provide more details on the depth and size of the scratches if you want more advice.
Exactly, this is important to know. Unfortunately, melamine-coated furniture is quite sensitive to scratches because you can't simply sand the surface without damaging the core material.
Sustainable means, in this case, not quick fixes but gentle care and targeted repairs.
I recommend:
- First, use a fine abrasive pad (e.g., sanding sponge with a grit over 400) and gently rub along the scratch—but only if the coating is still relatively lightly damaged.
- Then apply color-matched wax or repair paste.
- Finally, finish with a furniture polish based on natural ingredients.
This often gives good results for small to medium scratches.
I recommend:
I like to approach this with technical detail because sustainability also means keeping furniture looking good for as long as possible and avoiding unnecessary replacement.
A few important points:
- The Besta series often uses laminate or melamine-coated chipboard panels with a thin decorative layer.
- Scratches in the coating cannot be fixed by simple repainting since there is no paint layer to refresh.
- Small scratches can be visually concealed with wax sticks (also called furniture repair kits), but not fully restored.
- For deeper scratches where the chipboard is visible, filler material must be used carefully—preferably water-based to avoid swelling.
Here is a suggested process:
1. Clean the surface thoroughly so no dirt interferes with the repair.
2. Lightly roughen the area around the scratch with fine sandpaper (grit 600+), without sanding too deep.
3. Use a color-matched wax stick or wood filler to fill the grooves.
4. Gently wipe off any excess so that the repair area does not appear shinier than the surrounding surface.
5. After curing, treat the area with a microfiber cloth and a mild care oil or wax.
Questions: How large are the scratches? Are they superficial or noticeably deep?
Sustainability here primarily means "proper care + targeted repair" rather than "excessive intervention."
benonon schrieb:
Sustainability here primarily means "proper care + targeted repairs" rather than "over-intervention."I completely agree. I would like to add:
- Regular cleaning with only mild, pH-neutral cleaners helps avoid the use of harsh chemicals.
- For very minor scratches, rubbing in a small amount of edible fat (e.g., coconut oil) can provide a temporary improvement.
- An additional protective layer from furniture wax or oil-based varnish can make the surface more durable, but this is only partially recommended since the surfaces are often unsealed or thinly sealed.
To me, being sustainable also means extending the furniture’s lifespan as much as possible through careful use and targeted measures.
