ᐅ How can I properly level IKEA BESTA furniture on slightly uneven floors?
Created on: 27 May 2021 14:37
Swenpu
Swenpu
27 May 2021 14:37
Hello everyone, I am currently planning to set up my IKEA Besta furniture, but I have the problem that my floor is quite uneven – these are slight irregularities, not major bumps or holes. Now I am unsure about the best way to align the furniture precisely so that it doesn’t wobble or stand crooked. What methods or tools would you recommend to achieve as straight an alignment as possible on such floors? I would prefer not to have to constantly readjust and ideally avoid expensive specialized solutions. Thanks for your tips!
islaron
27 May 2021 15:04
Use the adjustable feet of IKEA BESTA on uneven floors. Small furniture wedges or foam strips under the feet can also help. This way, you can easily adjust the height and prevent wobbling.
PAR63
27 May 2021 16:28
Hello Swenpu, I’m happy to provide you with a simple step-by-step guide to perfectly level your BESTA furniture on slightly uneven floors:
- First, use a spirit level to identify the areas with the largest height differences.
- IKEA BESTA furniture has adjustable feet; use these to align the unit as precisely as possible.
- If the unevenness is very minor, you can additionally place thin felt pads or plastic shims under the furniture legs.
- Make sure all feet have firm contact with the floor to prevent wobbling.
- Finally, check the stability and alignment again with the spirit level.
A common mistake is to adjust the feet roughly. Spending a bit more time on fine-tuning will pay off in the long run.
nanidra
27 May 2021 18:13
PAR63 schrieb:
Make sure all the feet have solid contact with the floor to prevent the furniture from wobbling.
That’s really the key point. But honestly: IKEA is known for modular design, not for custom-made precision. Anyone expecting to perfectly install a flat-pack piece of furniture on an uneven floor needs a lot of patience or would be better off hiring a professional right away. In the end, these adjustable feet are, to me, more of a cosmetic fix—unevenness can only be partially compensated. Perhaps it makes more sense to think about leveling the floor beforehand instead of adjusting each furniture piece bit by bit.
KAUDRA62
28 May 2021 08:57
Hi Swenpu, I completely understand your concern! IKEA furniture on sloped floors? ☝️ Definitely not ideal. 🙂
My tip: Besides using adjustable feet and wedges, I sometimes use small self-adhesive anti-slip pads. They not only compensate for minor unevenness but also provide better grip. And if it really wobbles, try pulling the pieces slightly apart or securing them together with connectors – that helps stabilize things quite well.
You don’t have to become a professional; a bit of DIY usually does the trick. 😉
FELOTAU
28 May 2021 12:46
nanidra schrieb:
In the end, these adjustable feet are, to me, a bit of cosmetic detail; they only partially mask unevenness.
I understand that, and sometimes it can be really frustrating, especially when after a lot of effort you don’t achieve a perfect result. I also struggled with my BESTA until I simply accepted that a difference of a few millimeters (inches) doesn’t necessarily mean it will wobble. What’s important to me is that the piece of furniture stands firmly and doesn’t shake – which is usually achieved with a combination of adjustable feet and small shims.
If it does wobble occasionally, you can also experiment with silicone pads that have some give. All in all, it’s not rocket science, but a little patience is required. Good luck!
