ᐅ How can I paint Ikea Hemnes furniture myself without any paint runs?
Created on: 22 Dec 2021 19:37
tonureHello everyone, I am planning to repaint my Ikea Hemnes furniture myself and want to avoid unsightly paint drips at all costs.
I’ve read that painting these types of furniture, which have a somewhat coarse texture with an MDF base and veneer instead of solid wood panels, can be a bit tricky. So I’m mainly interested in which preparations, products, and techniques work best for achieving a smooth, even coat of paint without drips or runs.
For example, can I optimize the sanding process in a specific way, use special paint or primer, or is there an ideal brush or spray method you would recommend?
I want to be mindful of common issues like applying paint layers that are too thick or poor ventilation, which could lead to defects.
Thank you very much in advance for your advice!
Hey tonure, great question! I’ve personally painted a few Hemnes tables and dressers myself. It’s important to sand the surface very well, starting with 120 grit and then finishing with 220 grit for the best paint adhesion.
It’s best to use a spray gun or fine spray gun if you have one, otherwise use a good quality paintbrush and apply the paint thinly.
And very important: always work in thin layers and let each layer dry completely before applying the next. Otherwise, runs can form quickly!
If you apply the paint in several very thin layers, the result will be smooth and beautiful! Good luck, you can do it!! 😄
Landontau23 Dec 2021 08:14Hello tonure, here is a brief step-by-step guide on how I paint Hemnes furniture without risking runs:
- First, thoroughly clean and dust the furniture surfaces.
- Sanding is crucial: I recommend starting with 120-grit sandpaper, then follow up with 220-grit for a smoother finish.
- Apply a primer, preferably a water-based primer suitable for wood.
- Once dry, lightly smooth the surface with 240-grit sandpaper.
- Now apply the paint thinly; several thin coats are better than one thick coat.
- When painting, always brush or spray in one direction and avoid going back over brush strokes.
- Allow sufficient drying time between each coat at room temperature.
Common mistakes:
- Applying too much paint at once
- Being impatient and not allowing adequate drying time
- Incorrect sanding (too coarse after priming)
The result will be clean and almost free of runs.
Common mistakes:
I agree with Landontau and would like to add:
- It’s best to avoid cheap brushes, as they tend to shed fibers.
- Instead of varnish, you can also use a high-quality acrylic or acrylic-based furniture paint, which is often more fluid.
- It’s worth testing on a small area first to find the ideal layer thickness and the right brush.
- Ensure good ventilation, but avoid drafts that could stir up dust.
In summary: thorough sanding, thin coats, quality products, and patience are your best friends.
Landontau schrieb:
After drying, lightly smooth the surface with 240-grit sandpaper.Thanks, that’s very helpful! May I quickly ask: Should the sanding dust be thoroughly removed after each sanding pass, or is simply blowing it off sufficient? How important is this to avoid runs in the paint?
Also, should the paint be well stirred again before application, and what about the timing? After how many hours is it usually dry to the touch and safe to sand?
I just want to avoid damaging layers in between and creating new sanding dust issues.
