ᐅ How can I paint Ikea Hemnes furniture myself without any paint runs?
Created on: 22 Dec 2021 19:37
tonure
Hello everyone, I am planning to repaint my Ikea Hemnes furniture myself and want to avoid unsightly paint drips at all costs.
I’ve read that painting these types of furniture, which have a somewhat coarse texture with an MDF base and veneer instead of solid wood panels, can be a bit tricky. So I’m mainly interested in which preparations, products, and techniques work best for achieving a smooth, even coat of paint without drips or runs.
For example, can I optimize the sanding process in a specific way, use special paint or primer, or is there an ideal brush or spray method you would recommend?
I want to be mindful of common issues like applying paint layers that are too thick or poor ventilation, which could lead to defects.
Thank you very much in advance for your advice!
lalutau
23 Dec 2021 13:03
tonure schrieb:
Should sanding dust be thoroughly removed after each sanding, or is blowing it off enough?
Sanding dust must be completely removed, preferably with a slightly damp cloth, then allowed to dry. Simply blowing it off usually isn’t enough, as dust particles tend to stick and prevent a smooth paint application.
tonure schrieb:
Should the paint be well stirred again before application?
Yes, the paint should be mixed thoroughly but not shaken too vigorously to avoid air bubbles. The temperature of the paint is important – it should be at room temperature.
The paint is usually dry to the touch after 2–4 hours, depending on the product and room temperature. However, before sanding, I recommend waiting at least 6 hours, preferably 12, so the layer is fully cured and less prone to damage.
This minimizes unevenness and the risk of runs caused by contaminated layers.
rekijan
24 Dec 2021 11:15
Hey Tonure, a small add-on from me: If you don’t have a spray gun, a foam roller can work really well with liquid paint!
It applies the paint thinly and evenly, without those annoying brush marks – some call it the "miracle method" for furniture. Especially with Hemnes, it’s a nice alternative.
Important: After rolling, be sure to watch for drips and edges, and smooth them out immediately with a brush. This effectively prevents runs.
Also: Avoid applying layers that are too thick – your motto should be: better to do several thin coats! Good luck, sounds like a cool project!
Roberta
24 Dec 2021 12:20
rekijan schrieb:
After rolling, make sure to watch out for drips and edges, and immediately smooth them out with a brush.
This is exactly the crucial step; otherwise, runs will form. Thanks for the tip!
