ᐅ Which paints are suitable for painting Ikea HEMNES furniture?
Created on: 14 Nov 2020 08:37
jogladston
Hello everyone, I am planning to paint some of my Ikea Hemnes furniture myself but am unsure which types of paint work best to achieve a long-lasting, good-quality result. My furniture is made of solid pine, partly with a surface that is lightly lacquered or oiled. I want to avoid the paint peeling or looking uneven after a short time. It should also be considered that the furniture is frequently used, so the paint needs to be durable.
Does anyone know of suitable paint types and brands that are especially good for painting Hemnes furniture? What kind of preparation is recommended, and are there specific shades that stand out? I am also interested in whether chalk paint or acrylic paint is better, particularly regarding durability and appearance.
Thanks in advance for your advice!
edisondan
15 Nov 2020 08:21
I would like to emphasize that preparation is crucial for the final result.
Hemnes furniture is made from pine, which is relatively soft and has a smooth surface. Light sanding creates a better surface for the paint to adhere to.
For chalk paints, I strongly recommend sealing, as these paints are not inherently abrasion-resistant. The sealant can be a clear varnish (matte or satin finish).
For durable use, I recommend a two-component PU lacquer, if conditions allow. However, these are more difficult to apply and often require professional skills.
For most DIY enthusiasts, a high-quality acrylic paint with a good primer is the best combination of durability and ease of application.
tangi
15 Nov 2020 10:34
In summary, it is noticeable that the choice of paint depends heavily on the level of use.
- For furniture with light use, water-based chalk paints combined with a hard wax finish work well.
- For heavily used furniture, a matte or satin acrylic lacquer combined with an appropriate wood primer is recommended.
I suggest
- Thorough surface preparation before painting (sanding, removing dust)
- Applying at least two coats for an even and durable paint layer
Another important tip: Avoid applying paint layers that are too thick, as they are more likely to crack under stress. Thin, well-dried layers result in a longer-lasting finish.
EDWARD0
16 Nov 2020 09:11
I have had good experiences with water-based acrylic paints. They have low odor, dry quickly, and result in a durable finish.
When working on pine wood, such as with HEMNES, preparation is key: always sand before painting and use an appropriate primer.
theota
16 Nov 2020 11:58
kauti schrieb:
Chalk paints are decorative but usually require a protective sealant, such as hard wax or clear varnish, because otherwise they are not abrasion-resistant enough.
That’s true. Although personally, I think some trends tend to overlook the practical aspect of painting furniture. The color alone doesn’t determine quality.
Alberto51 schrieb:
However, you have to be aware that chalk paint without protection is quickly vulnerable.
Especially with items that are used daily, wear becomes visible over time if you don’t focus on durability and protection when painting. But of course, if you want that look, you just have to do the work more often.
I still stand by this: If you want to repaint HEMNES furniture and avoid constant touch-ups, water-based acrylic lacquer is the best choice.
klo40
17 Nov 2020 07:05
This is one of the most important requirements. Therefore, here is a final tip for the application process:
- Each coat of paint should be applied thinly, preferably using a high-quality brush or a foam roller designed for smooth surfaces.
- Lightly sand between coats (e.g., with 220 grit) and thoroughly remove any dust.
- Be patient during drying; it’s better to allow extra time than to apply the next coat too soon.
This will help you achieve an even, long-lasting finish that can withstand everyday wear and tear.
