ᐅ How can I optimize the cleaning of IKEA Metod kitchen fronts when dealing with heavy grease?
Created on: 13 Aug 2020 10:07
sabina55
sabina55
13 Aug 2020 10:07
I have an IKEA METOD kitchen with high-gloss white fronts. Unfortunately, due to frequent cooking and frying, a strong grease film develops quite quickly on the fronts, especially around the handle areas and near the cooking zone. I want to improve the cleaning of the kitchen fronts without damaging the surfaces or affecting the coating. Are there any proven cleaning methods or special products that are more effective against heavy grease than regular household cleaners? Additionally, I am interested in how to prevent heavy grease buildup in the long term. Who has experience or tips for effectively removing grease from IKEA METOD kitchen fronts while preserving the material quality?
kla65
13 Aug 2020 10:21
For heavy grease buildup, a mixture of dish soap and warm water is often sufficient. To protect the surface, clean with a soft cloth and then wipe again with clean water. Avoid using abrasive cleaners or scrubbing pads.
LANICOLE
13 Aug 2020 11:04
To optimize the cleaning of IKEA METOD kitchen fronts with heavy grease, I recommend the following step-by-step plan:
- Preparation: First, wipe off coarse dirt and grease with a damp microfiber cloth.
- Use a degreaser: Use mild, grease-dissolving cleaners, preferably liquid dish soap or specialized kitchen cleaners, but avoid harsh chemical additives.
- Let it sit: Allow the cleaner to work for 5–10 minutes, but do not let the surface dry out.
- Gentle cleaning: Clean with a soft sponge or cloth in circular motions to avoid damaging the coating.
- Rinse: Remove residue with a damp cloth and clean water.
- Drying: Dry with a lint-free cloth to prevent water spots.
Common mistakes include using abrasive cleaners or strong bleaches, which can roughen the surface or dull the gloss finish. Aggressive scrubbing should also be avoided. In the long term, it helps to remove grease immediately after cooking and clean the kitchen fronts regularly to prevent stubborn buildup.
Lilygla
14 Aug 2020 09:27
Your question is very precise and important, as high-gloss fronts in METOD kitchens are particularly sensitive to the wrong cleaning agents and methods. I would like to explain a bit more in detail about cleaning heavy grease, including some technical background information.
The surfaces are usually melamine-coated or have an acrylic layer; both are water-resistant but prone to scratches and chemical damage. This means the choice of cleaner and cleaning aids is crucial.
1. Grease-dissolving agents: Ideally mildly alkaline to effectively bind grease. Dishwashing liquids are common, but for heavy soiling, citrus-based cleaners or special grease removers (without solvents) can be helpful.
2. Mechanical cleaning:
- Do not use rough sponges or scouring pads.
- Use microfiber cloths or very fine sponges.
- Clean very gently in circular motions to avoid micro-scratches.
3. Procedure:
- Apply the cleaner generously and let it soak for a few minutes; do not let it dry.
- Soaking helps to loosen stubborn grease films.
- Re-wet if necessary and then wipe off carefully.
4. Surface care advice:
- After cleaning, wipe the surfaces with clear water to remove any cleaner residue.
- Once dry, an antistatic care cloth can be used to reduce future dust and grease buildup.
5. Prevention:
- Reduce grease during cooking, for example by using an extractor hood and lowering ventilation covers.
- Clean fronts regularly, preferably at least every two days.
I am curious if you have already tried certain cleaners and what the results were? Also, do you have increased exposure to heat directly on the fronts (e.g., steam), which could potentially set the lipid films?
U
usbla
14 Aug 2020 13:45
Lilygla schrieb:
Surfaces are usually melamine-coated or have an acrylic layer; both are water-resistant but prone to scratches and chemical damage.
This is an important note. I would like to add that with heavy grease, the water temperature is also relevant: lukewarm water is sufficient, while hot water can damage the coating, especially if harsh cleaners are used on top of that.
Furthermore, I recommend the following products:
- Neutral dishwashing detergents without bleaching agents
- Grease-dissolving cleaners specifically designed for kitchen surfaces, without ammonia and without abrasives
Using a microfiber cloth helps mechanically break down the grease without causing damage.
Also, after cleaning, the areas should be dried off, as standing water on melamine-coated surfaces can lead to unsightly marks.
In the long term, the best strategy is a combination of regular cleaning and avoiding direct contact with hot grease particles, for example by using a good extractor hood.
Dirkmin
15 Aug 2020 07:52
sabina55 schrieb:
I want to optimize the cleaning of kitchen fronts without damaging the surfaces or affecting the coating.
To avoid damaging the surface, it is essential to pay attention to the pH value of the cleaning agents used. Neutral cleaners (pH 6–8) are best suited.
For stubborn grease deposits, I recommend a two-step process:
- First, treat heavy grease spots with a mild, grease-dissolving cleaner.
- Then wipe thoroughly with a damp microfiber cloth without any additives.
Ideal are special cleaners designed for coated kitchen furniture that dissolve grease but do not contain abrasive substances. On the market, there are enzyme-based cleaners that remove grease more effectively than pure surfactants.
Please never use scouring agents or aggressive solvents such as acetone or denatured alcohol on METOD fronts!
