ᐅ How can I optimize the installation of Ikea Metod cabinets on uneven floors?
Created on: 26 Jul 2023 12:21
jakubus
I am planning to install several Ikea Metod kitchen cabinets in my apartment, but I am facing a problem that some of you might be familiar with: the floor in my room is not completely level, which makes assembling and aligning the cabinets challenging.
My specific question is: What practical methods, tools, or installation tips do you have to ensure a stable and level setup of Ikea Metod cabinets on uneven floors? I am interested in both mechanical solutions (such as shims, adjustable feet, or anchoring techniques) and practical advice from experience, for example on managing tolerances or adjustment options during assembly.
If you have dealt with similar situations or can recommend certain tools, I would greatly appreciate your suggestions and more detailed explanations on how to optimize the installation so that the cabinets stand flush and secure without wobbling or pressure marks.
Best regards and many thanks in advance for your tips!
klo61
26 Jul 2023 17:50
Hello jakubus,
For height differences up to 2.5 cm (1 inch), I would also recommend considering a leveling underlay.
- Material: Multiplex boards (at least 15 mm (0.6 inches)) are durable, dimensionally stable, and can be coated to resist moisture. Another option are HDF boards or waterproof OSB boards. In any case, make sure to secure the board firmly to the floor to prevent it from slipping.
- Installation: You can cut the board to size and, if necessary, use wedges underneath uneven spots to create a relatively level surface.
- Stability: Placing the cabinets on a continuous underlay actually improves stability because the weight is distributed evenly. It’s important to adjust all the cabinet feet precisely to this surface.
- Connection: Ikea Metod cabinets are connected to each other with connector screws. As long as they are all at the same height, it doesn’t matter whether they are installed directly on the floor or on the leveling board.
If the height becomes too high, you can adjust the plinth height or, if possible, reduce the thickness of the board by cutting it down.
Hope this helps you with your decision.
JONSON
26 Jul 2023 19:34
I would like to emphasize the adjustment of the individual cabinet feet once again:
- Check each cabinet foot for proper function before installation and fix any defects.
- In practice, unevenness can often be well compensated with layered shims made of rubber, wood, or plastic.
- Make sure to use non-slip materials to prevent shifting later on.
My tip: Do not fully assemble the cabinets upfront; instead, continuously align and push them together temporarily. This will help you avoid alignment issues after final assembly.
And importantly: No matter how well you level the cabinets, wall mounting is essential to permanently prevent tipping hazards.
Santi
26 Jul 2023 20:11
I always fully extended the legs of the Metod cabinets on uneven floors and then supported them with wooden shims. After that, I checked the legs again and secured the cabinets to the wall. This allowed everything to be aligned stably and evenly.
gesar32
27 Jul 2023 09:42
A few additional notes:
- For unevenness greater than 2 cm (0.8 inches), do not rely solely on the self-leveling feet.
- A mounting plate made of plywood is a very good idea, but it also adds some height that you need to factor in.
- Make sure the entire mounting station is securely fastened to the wall with screws, as this is the only way to ensure long-term stability of the cabinets.
- It is advisable to check floor unevenness using a simple profile and a spirit level, and record these measurements. This will help you plan the leveling material more accurately.
- Plastic washers are useful, but they can shift over time, so always place non-slip pads underneath.
- Finally, during installation, verify once more with a laser level or a precise spirit level that the fronts and the cabinet body align properly, to prevent any gaps later on.
klo40
27 Jul 2023 12:58
jakubus schrieb:
Which materials are particularly suitable as underlayment in such cases (moisture-resistant, dimensionally stable, not too thick)?
I would like to add:
- HDF boards (High-Density Fiberboard) are often more affordable than plywood and offer good dimensional stability, making them suitable for dry areas. For wet areas, there are impregnated versions available.
- PVC boards or special plastic panels can also be useful; they are moisture-resistant and quite thin but usually more expensive.
- Pay attention to thickness: 12–15 mm (about 0.5–0.6 inches) is generally optimal; thinner options may risk instability.
- If you choose plywood, it’s recommended to seal the cut edges with paint or a sealant to prevent moisture ingress.
- Wooden shims work well for small height adjustments but are not a long-term solution for larger areas.
These options provide various ways to ensure a straight and stable installation.
