ᐅ How can I secure Ikea BESTA doors magnetically?
Created on: 24 Dec 2021 10:03
Miusleo
Hello everyone, I am currently having an issue with my Ikea Besta doors, as they do not close properly when I simply push them shut. I would like to secure them magnetically so that they stay firmly and reliably closed without getting stuck or needing constant adjustment.
Therefore, my question to you is: How can I magnetically secure Ikea BESTA doors in a way that is as discreet as possible? Are there specific magnetic systems or kits that fit particularly well? Should I attach the magnets to the door or the frame? What accessories do you recommend to ensure the doors close quietly and durably?
I would also like to know the best approach to avoid unsightly drill holes or damage. I appreciate all tips and experiences!
tutan
25 Dec 2021 12:17
Miusleo schrieb:
Does anyone have a recommendation for a specific strength (e.g., in Gauss or Newton) that is suitable for the weight of the Ikea BESTA doors?
Here’s a quick note about strength: I have had good experience with 10 x 3 mm neodymium discs, which have about 4 to 5 kg (9 to 11 lbs) of holding force and are not too overpowering.
This is actually ideal for BESTA because they hold strongly enough but still allow the doors to be opened with little effort. And yes, the hinges don’t suffer at all – after all, they handle the door movement, while the magnets only provide the holding force.
blapau
26 Dec 2021 07:44
An important aspect when using magnetic catches for Ikea BESTA doors is the surface where the magnets are attached. It should be free of grease and dust to ensure the adhesive tape lasts a long time.
Additionally, it is advisable to measure the exact dimensions of the doors, preferably using a caliper or a precise ruler, so the magnets align accurately when the doors close.
My tip: Also check if the doors are slightly warped, as this can affect the effectiveness of the magnetic fastening.
Repar
26 Dec 2021 09:12
Attach magnets with adhesive tape on the inside of the door frame and door. Clean the surface thoroughly. Magnet size 10x3 mm (0.4x0.1 inches) neodymium magnets are ideal for BESTA doors.
