Hello everyone, I am currently having an issue with my Ikea Besta doors, as they do not close properly when I simply push them shut. I would like to secure them magnetically so that they stay firmly and reliably closed without getting stuck or needing constant adjustment.
Therefore, my question to you is: How can I magnetically secure Ikea BESTA doors in a way that is as discreet as possible? Are there specific magnetic systems or kits that fit particularly well? Should I attach the magnets to the door or the frame? What accessories do you recommend to ensure the doors close quietly and durably?
I would also like to know the best approach to avoid unsightly drill holes or damage. I appreciate all tips and experiences!
Hey Miusleo, I’m familiar with the issue with BESTA doors—they sometimes don’t close as smoothly as you’d like! 😄
Regarding magnetic securing: I use small neodymium magnets, which I attach inside the frame and on the door contact surface. It’s important that the magnets are strong enough to hold the weight of the door but not so strong that you risk pinching your fingers.
It’s best to choose flat magnets fixed with strong 3M double-sided tape, so you don’t have to drill—this looks neat and holds extremely well. The top approach is to position the magnets so the door and frame align perfectly—this takes a bit of fiddling during installation, but it’s worth the effort!
Good luck and enjoy creating your magical doors!
Hello Miusleo, I have carefully read your question and will provide you with a structured answer on how to securely and magnetically close Ikea BESTA doors:
- First, determine the optimal position where the magnet works best. Usually, the inside of the door frame is the ideal mounting location.
- Choose strong neodymium magnets with a thickness of about 3-5 mm (0.12-0.2 inches). Flat disc shapes are ideal for aesthetic reasons.
- It is important to polarize the magnets correctly so that the door and frame attract each other rather than repel.
- Attach the magnet and metal plate preferably using high-quality double-sided adhesive tape, such as 3M VHB, which holds firmly without drilling.
- Alternatively, you can stick small metal plates to the back of the door and mount the magnets on the frame.
Common mistakes:
- Wear and tear of adhesive tape, especially if surfaces are not clean.
- Choosing magnets that are too weak.
- Incorrect alignment causing the door not to close properly.
Conclusion: With careful measuring and strong, flat neodymium magnets fixed with adhesive tape, you can magnetically and discreetly secure BESTA doors. If you need a step-by-step illustrated guide, I can provide details in a separate post.
Common mistakes:
bulanau schrieb:
Choose strong neodymium magnets with a thickness of about 3–5 mm (0.12–0.20 inches). Flat discs are ideal for aesthetic reasons.Thank you for the clear explanation! I am particularly interested in whether you have experience with the impact on the hinge when securing doors with magnets – are there any limitations or risks?
Also: Does anyone have a recommendation for a specific strength (e.g., in Gauss or Newton) that would be suitable for the weight of the Ikea BESTA doors? I want to avoid the door wobbling unpleasantly when opened due to magnets that are too weak, or being too strong and making closing difficult.
Thanks in advance!
Regarding magnet strength for Ikea BESTA doors: I recommend magnets with a holding force of at least 3-5 kg (6.6-11 lbs), depending on the door size and mounting.
Smaller magnets with less than 2 kg (4.4 lbs) holding force are usually too weak, and the door will not close reliably. If the magnets are too strong, opening can become difficult, but this is usually not a big issue if you pull firmly.
Concerning hinge load: magnetic catches do not put more stress on the hinge than a regular snap latch. The important thing is that the doors are properly aligned.
A small tip: if the doors slam loudly against each other, you can also attach a thin felt strip to reduce noise and protect the material.
