ᐅ How can I install Ikea PLATSA units in a rental apartment without using a drill?
Created on: 30 Aug 2020 08:12
Kotar58
Hello everyone, I bought the Ikea Platsa system, but I want to install the cabinets in my rental apartment without drilling, since drilling into the walls is not allowed and I want to be able to move out without leaving damage. The cabinets need to be stable and not tip over, especially when they are tall. Are there any proven methods or alternatives to the included fasteners, which usually require drilling? I was thinking of clamp or tension-based solutions or possibly adhesive strips/hooks that are strong enough. Has anyone had similar experiences and can offer useful advice on how to safely secure Ikea PLATSA without drilling? Thanks in advance!
barEsperan
31 Aug 2020 09:46
The extra-strong adhesive tapes from 3M can hold quite a bit, but are hardly sufficient for tall shelves bearing heavy loads. For proper stability, only mechanical fastening between floor and ceiling or a tension rod system will help.
Nadine
31 Aug 2020 11:22
barEsperan schrieb:
For proper stability, only mechanical fastening between floor and ceiling or a rod with a plug-in system helps.
I agree with that. Especially with Platsa’s flexibility, this would be the best approach.
Also, keep the following in mind:
- Use furniture connectors to join modules into a single unit.
- A ceiling support post provides upward stability and prevents tipping over.
- Use adhesive pads only as supplementary support, not as the sole securing method.
This way, you ensure safety, even in households with children.
tutan
1 Sep 2020 06:43
Nadine schrieb:
A ceiling support provides upward stability and prevents tipping over.
Good tip! And another thing: placing some rubber granules or anti-slip pads under the feet helps a lot, especially if you don’t want to drill holes and the furniture is on a smooth floor.
Then the PLATSA will stand almost by itself. Of course, this doesn’t replace proper anchoring, but the combination of “clamping at the bottom” plus “preventing tipping” is a really great alternative!
And hey: as a tenant, it’s worth staying open to discussion when it comes to small drillings—some things are actually tolerated, especially if they can be properly reversed.
