ᐅ How do I install IKEA Metod toe kicks without visible fasteners?
Created on: 26 Jul 2022 08:17
ANATOLIAI plan to install the kickboards on my new IKEA Metod kitchen, but I definitely want to find a way to attach them without any visible screws or fasteners on the outside. The standard Metod kickboards usually come with small clips or can be fixed with screws that are visible from the outside – which I don’t like aesthetically.
My questions are: What is the best way to mount the IKEA Metod kickboards so that the fastening remains invisible? Are there special clips or installation methods for this? Do I maybe need to modify the cabinet carcass or the kickboards themselves? I want the whole setup to not only look clean but also be stable, especially considering the daily demands of a kitchen.
Has anyone had experience with this kind of installation or maybe even a guide or tips that go beyond the usual screwing? Any advice on fastening methods, choice of materials, and procedure would be very helpful. Thanks in advance!
The easiest way is to use the original IKEA clips. They are attached to the carcass, and then the trim piece is snapped into place. The screws are on the inside, so nothing is visible from the outside. If you want it to be sturdy, you can distribute the clips at several points.
For the invisible installation of Metod baseboards, I recommend a step-by-step approach that I often use myself:
- First, check if you have the original Metod baseboards, as there are different versions.
- The installation is done using special clip brackets, which are often included with the baseboard. You screw these brackets in from the inside of the cabinet frame.
- Important: Use a cordless drill with a depth stop to avoid driving the screws too deep and damaging the cabinet frame.
- Then simply click the baseboard into place. The clips snap in so that no screw heads are visible from the outside.
- If no clips are available, you can purchase them separately or make suitable aluminum or plastic brackets.
It is also important that the baseboards are not just clipped in but securely fixed, as kitchen stresses like moisture or impacts occur. Sometimes it makes sense to additionally secure the baseboard inside the cabinet frame with thin double-sided mounting tape if there is slight movement.
Another option is magnetic brackets, although this is rather uncommon and requires modifications. How technically skilled are you with this kind of work?
kibutar schrieb:
If no clips are available, you can buy them individually or make suitable aluminum or plastic holders.Thank you, this idea sounds helpful. I have all the mounting materials from IKEA, but the included clips seem a bit unstable to me, especially at the corners. Can anyone advise how to best attach the corner connectors without visible screws on the outside? Is this usually solved with clips, or is another method needed?
Also, I am using somewhat older cabinet carcasses— is there anything specific to keep in mind when adjusting the baseboard mounting?
I think it’s important to question the stability when there are no visible fasteners.
Corners are generally a weak point. Simple clips usually aren’t enough here because they only hold at specific points.
I would recommend gluing the corner joints in addition, then securing them from the inside with short screws, which can later be covered with matching caps. This would provide significantly more stability while remaining invisible from the outside.
Alternatively, custom-made angle brackets made of aluminum or plastic can be fixed with screws from the inside and placed onto the trim pieces.
Ultimately, it’s about balancing the aesthetic goal against the physical stress.
ANATOLIA schrieb:
I have all the IKEA assembly materials, but the supplied clips seem a bit unstable to me, especially at the corners.
I would like to add that the surface of the baseboards should not only look neat but also be easy to clean and resistant to occasional impacts or moisture.
In practical daily use, I have had good results with the original clips plus additional hook-and-loop tape or double-sided mounting tape on the baseboards. This ensures the baseboards do not shift under stress.
Regarding corners: If the clips do not hold there, I have briefly fixed the baseboards at the corners with superglue. This creates a strong connection that appears as a seamless corner from the outside.
It is also important to align the baseboards as flush to the floor as possible during installation; otherwise, the clips may quickly loosen.
