ᐅ How can I install IKEA Metod kitchen units in tight spaces?
Created on: 29 Aug 2021 18:37
Lelis52
Lelis52
29 Aug 2021 18:37
I am facing the challenge of planning and installing an IKEA Metod kitchen unit in a very tight space. My room is only 2.20 meters (7 ft 3 in) wide, so every single footprint and centimeter (inch) of countertop space is extremely valuable. I am wondering how to proceed as efficiently yet practically as possible to make the best use of the space.
What experiences do you have with installing kitchen units in such limited spaces? Are there any special considerations for the Metod system that make the installation easier? How do you ensure that despite the tight space, all connections – water, electricity, drainage – are technically feasible?
I am also interested in any tips you have on accurate measuring, planning, and potentially implementing unconventional solutions to maximize the space. Additionally, I have some open questions about installation methods, especially regarding stability and optimizing storage space.
I look forward to your detailed tips and experiences!
Parbo
29 Aug 2021 19:04
Hello Lelis52,
your question about IKEA Metod kitchen units in tight spaces touches on an issue that many underestimate. I have planned and built several compact kitchens myself, so here is a detailed process that might help you:
- Planning and precise measuring: Start with a very accurate room survey. Measure not only the visible dimensions but also the depth of the walls, especially at the height where the connections are. There are often awkward niches or protrusions that must definitely be accounted for.
- Assembly of the individual base cabinets: With Metod, precise alignment is crucial. I recommend aligning all cabinets individually first before assembling the entire setup. Height adjustment plays a major role, especially with uneven floors, which are common in older buildings.
- Technical connections: If the pipes and cables at the back are very tight, you can often modify or partially omit Metod back panels. There are also very shallow connection rails that you can install behind the baseboards. Always measure beforehand whether outlets and water connections allow enough clearance.
- Storage optimization: Use internal drawers and corner solutions like carousels offered in the Metod range. These usually solve the problem of lost storage space despite a small footprint.
- Assembly methods: Work step by step and only fix everything with screws once your alignment is correct. No matter how tight the space is, it is worth not compromising on stability—especially if you want to install heavy appliances.
If I were you, I would also be interested to know: Do you already have prefabricated measurements or plans, or are you still in the shell construction phase? What electrical and water connections are available? Then I could provide more targeted advice for your situation.
NOAHSAU
29 Aug 2021 20:16
Parbo schrieb:
If the pipes are very tight on the back, you can often adjust or partially omit Metod backs.
This is exactly the issue I question with IKEA kitchens in general: Why are adjustments made to the main frame? Metod is not the same as a carpenter’s custom fit. The tolerances are not ideal for many spaces, especially tight ones.
You might almost think IKEA is deliberately challenging DIYers with their modular designs – a little adjustment here, a screw there – and suddenly the flexibility is severely limited.
My personal view: If the space is tight, you should either use custom-made alternatives or measure the room very precisely to modify potential IKEA components in advance. The pandemic has also shown how important individuality is – something I find lacking in Metod.
Carousels and pull-outs are all very nice, but if the connectors don’t fit, it gets frustrating!
I would also definitely consider having a small module completely custom-built by a carpenter if in doubt – or at least adjust the fronts yourself.
puvin
30 Aug 2021 07:21
Hey Lelis52!
I totally understand how challenging this can be – but keep your spirits up, with Metod you can achieve a lot! 😊
I built a Metod kitchen unit myself for my small kitchen, which is only 2 meters (6.6 feet) wide, and here’s what I learned:
- Precise measuring was key! A laser measure is best if possible.
- I paid special attention to the center lines of the appliances to ensure the oven and sink were perfectly aligned.
- For such narrow rooms, don’t worry too much about extravagant corner solutions, as they often take up too much space.
- Internal drawers in the lower cabinets really increase storage space – they helped me keep everything organized and within easy reach!
If you want, I can also share some small tips on how to fit the baseboards really snugly against the appliances, which greatly improves the overall look.
Keep at it, it will turn out great – you’ve got this!
PEDRO40
30 Aug 2021 11:49
Lelis52 schrieb:
What are your experiences with installing kitchen units in such tight spaces?
I recently had a similar setup. It wasn’t just about the dimensions, but also about not wanting to feel cramped in the small space.
What helped me was choosing very light-colored cabinet fronts and a continuous countertop, as this makes the room appear visually larger.
I also tried to select appliances as compact as possible (24 inches (60cm) width is already quite tight; 20 inches (50cm) would have been even better here).
Don’t stress too much if something doesn’t fit perfectly – flexibility is essential in a small apartment.
By the way, I also think IKEA Metod is a great starting point, but depending on your requirements, you should expect some modifications, like trimming fronts or partially relocating water connections. If you’re unsure about this, it’s better to involve a professional.
It slows down the whole project but saves a lot of headaches.
