ᐅ Planning Ikea Metod Kitchen Units Ergonomically and Space-Efficiently
Created on: 25 Jul 2020 09:17
Z
Zargrayson
Z
Zargrayson
25 Jul 2020 09:17
Hello everyone, I am currently planning my new kitchen with Ikea Metod and facing the challenge of designing the kitchen layout to be ergonomic while also as space-saving as possible.
I am particularly wondering how to optimally adjust the working height, as I have read that this is crucial for ergonomics. I am also interested in how corner cabinets can be used to maximize storage space without making it impractical.
Has anyone had experience planning Metod kitchen layouts, especially with a focus on ergonomic workflows and space-saving solutions?
What tips do you have, for example, regarding the arrangement of the individual units (base cabinets, wall cabinets, countertops) and the integration of appliances to avoid long distances and unnecessary movements?
I would appreciate concrete suggestions, possibly including advice on common mistakes to avoid.
dijan
25 Jul 2020 10:03
Hey, great topic! 😃 I think the biggest advantage of the Ikea Metod system is its flexibility, and the key to good ergonomics often lies in mentally mapping out your typical kitchen tasks beforehand.
Regarding the working height: I chose 91 cm (36 inches) and it works well for me at 1.80 m (5 ft 11 in). I found a mix of tall and low base cabinets quite practical, depending on what you're doing (chopping or washing up).
Corner cabinets are great, but carousel units can sometimes take up a lot of space – so it’s worth measuring carefully. I would also recommend positioning the sink and stove so that your main work surface is right next to them. This helps avoid long walks around the kitchen.
toril
25 Jul 2020 11:25
For ergonomics in Metod kitchen units, I strongly recommend considering the following points:
- Worktop height: It should be about 10–15 cm (4–6 inches) below the elbow when the arm is relaxed and hanging down.
- Storage use: Optimize corner cabinets with pull-outs or a Magic Corner to ensure accessibility and avoid dead corners.
- Planning the work triangle of sink, stove, and refrigerator: Ideally, no distance between stations should exceed 120 cm (47 inches) to minimize unnecessary walking.
- Choose uniform fronts and handle positions to ensure consistent usability.
Integrating the countertop space between the stove and sink is crucial for efficient workflow.
Naomige
25 Jul 2020 12:48
I had also planned a Metod kitchen unit and can add from experience:
- Be sure to include spacious pull-out base cabinets for herbs, oils, and pots near the stove.
- For the countertop, I recommend laminate with a wood design, as it is durable and easy to maintain.
- Use the tallest possible base cabinets with integrated inner drawers to maximize storage space.
- Avoid too many wall cabinets if possible, as they can significantly limit movement in the kitchen.
Regarding corner solutions, I chose the carousel cabinet, but found the layout was not ideal for larger pots.
DUUS32
25 Jul 2020 13:57
I completely understand how frustrating it can be when the kitchen ends up uncomfortable and you constantly have to stretch awkwardly. I felt the same way when I planned my first Metod kitchen.
What helped me was carefully visualizing the workflow – from shopping to cooking – and assigning a specific place for each activity. This way, everything feels logical, and you don’t have to keep searching for things.
If you’re planning on your own, this might add extra pressure, but don’t get discouraged. Designing a kitchen is a process – sometimes you get a little annoyed before everything falls into place.
PIERCE
25 Jul 2020 15:22
Corner cabinets with a Magic Corner are efficient but expensive. Alternatively: swing-out pull-outs.
Set the countertop at 90 cm (35 inches) if you are about 175–180 cm (69–71 inches) tall.
Kitchen work triangle: optimize the distance between the stove, sink, and refrigerator. Not too close, not too far.
