ᐅ How do I install IKEA Metod cabinet doors with soft-close hinges?
Created on: 14 Mar 2023 17:43
bentonHello everyone, I am about to install my new Ikea Metod kitchen doors and have chosen the version with the soft-close feature. However, I am unsure about the exact order of assembly and the correct settings for the hinges. Specifically, I am interested in the following points: How can I best attach the doors to the Metod cabinets without affecting the soft-close mechanism? How should the adjustment be done to ensure the doors close evenly and the soft-close system works properly? Are there any special tips regarding screws, spacers, or other small parts that I should keep in mind? I would appreciate a detailed step-by-step guide or advice on how to avoid common mistakes. Thank you in advance!
I understand your concern regarding the soft-close feature on Ikea Metod doors, but it would be helpful to know whether you are using the original Ikea soft-close hinges or aftermarket versions. This can make a difference in installation and adjustment.
Basically, Ikea uses a simple click system for the hinges on Metod, which integrates the soft-close function. The crucial point is that the hinges need to be installed at the correct depth – being too tight or too loose can significantly affect the damping.
Adjustments in height, depth, and lateral position should always be made gradually, and not all settings should be changed at once.
Are there any specific problems you are encountering when aligning the doors? I ask in order to address potential issues more precisely.
benton schrieb:
How do I best attach the doors to the Metod carcasses without affecting the soft-close mechanism?
cassandra15 Mar 2023 08:31In addition to the previous answer: The installation and adjustment of the Ikea Metod soft-close doors follow clearly defined steps that are important for functionality and durability:
- First, mount the hinges on the inside of the door, ensuring the mounting holes align precisely.
- Then, hook the hinge into the designated opening on the cabinet carcass and snap it into place.
- Next, use the three adjustment screws to fine-tune the door’s height, depth, and lateral position.
- For soft-close functionality, it is especially important that the screws controlling the damping (if present) are correctly adjusted; otherwise, the door may close too quickly or not close smoothly.
Many issues arise from over-tightening the screws or improperly inserting the hinges into the drilled holes. To check, open and close the doors several times and adjust the settings as needed.
A tip: Before fully tightening, do a complete check—all doors should close in sync.
cassandra schrieb:
The assembly and adjustment of the Ikea Metod soft-close doors follow clearly defined steps that are important for their function and durability:That’s true, and I would like to add: when installing the doors, you should first hang all the hinges correctly and then adjust each door step by step, instead of tightening all the screws at once.
farje schrieb:
Are there any specific problems you’re having with the alignment?Sometimes the hinges may not be positioned with millimeter precision because the drill holes can vary slightly. In that case, it helps to make small corrections using the adjustment screws until the soft-close function works properly and the doors close without resistance.
Also, the soft-close mechanism is sensitive to dirt—if dust or grease gets into the dampers, their effectiveness can be reduced. That’s why it’s important to work cleanly during installation.
I recommend having the Ikea assembly instructions handy as well; they are usually detailed enough and include helpful illustrations.
