ᐅ How do I install IKEA Metod cabinets with floor-to-ceiling walls?
Created on: 12 Jul 2022 14:07
Pifeka
Hello everyone, I am currently planning to install an IKEA Metod kitchen unit, but there is a particular challenge: the walls in my kitchen are floor-to-ceiling height, about 2.80 meters (9 feet 2 inches), most likely a bit higher than typical standard ceilings. My question to you is how to best adapt the Metod cabinets to this tall wall? Are there any recommendations for installation, adding extension panels, or even modifications to use or close the gap between the cabinets and the ceiling effectively? I am especially interested in whether it’s possible to use special IKEA accessories or if it’s smarter to make custom adjustments myself. I look forward to your experiences and tips so that I can achieve this as space-saving, stable, and visually appealing as possible. Thanks in advance!
Friedrich
13 Jul 2022 10:14
Hello Pifeka, I completely understand why you feel uncertain! I had a similar experience during a kitchen renovation when I encountered an issue with a corner attachment. At that time, I installed the wall brackets using additional heavy-duty anchors. This definitely provides a more secure feeling, especially if you plan to add heavy elements on top.
Pifeka schrieb:
I’m wondering: Does anyone have experience with how the extra weight pressure affects the standard wall brackets when additional strips or cabinet units are mounted on top?
I would also recommend two to three mounting points per cabinet, particularly for long runs. This ensures an even load distribution and reduces the risk of the cabinets warping or coming loose later. Safety comes first and makes daily use much easier!
raulso
13 Jul 2022 13:28
Friedrich schrieb:
I would also recommend two to three support points per cabinet, especially for long runs.
To be honest, with a bit of humor and the right tools, it doesn’t feel complicated at all. Just imagine you are building your own backdrop for the upcoming cooking show at home.
And yes, the attachments on top are like the finishing hat on your cabinet! Important: assemble together, mount securely, then everything is safe.
A little tip: if you’re really concerned about the height, you can create a nice atmosphere with suitable LED lights on the ceiling; playing theme music is optional 😉
jodeo58
14 Jul 2022 08:23
Mounting strips can be easily unscrewed and shortened if they are too wide or too long. Wood can be neatly adjusted with a chisel if you have custom gaps at the ceiling.
meoreo
14 Jul 2022 09:57
For stability: You can also use shelf brackets and additional screws to distribute the heavy load. Sometimes, a small metal plate behind the cabinets is also a good idea.
Hannah
14 Jul 2022 10:22
If you don’t necessarily want fully enclosed cabinets, you can also install open shelves at the top. This lightens the look and is easier than adding more heavy doors.
Naomige
14 Jul 2022 11:48
Pifeka schrieb:
My question to you is how to best adapt the Metod cabinets to this tall wall? Are there any recommendations for installation, adding extension trims, or even modifications to effectively use or close the gap between the cabinet and the ceiling? I am especially interested in whether it is possible to use specific IKEA accessories or if it is smarter to make custom adjustments myself.
In conclusion, I would say that it is usually best to use standard accessories to avoid risking warranty conditions, and to consult a professional if the height deviates significantly from the standard. DIY is great, but sometimes professional modifications make life easier!
