ᐅ What is the best way to install IKEA Metod cabinets on sloped ceilings?
Created on: 16 Jul 2020 08:23
Klodeniz63
I’m planning to install new IKEA Metod kitchen cabinets in my attic. The challenge is the sloping ceiling above the countertop, which slopes down on one side. Now I’m faced with the task of adapting the cabinets accordingly, since standard cabinets don’t fit well in that space.
I’m interested in how you have handled similarly challenging sloped ceilings in your rooms with IKEA Metod cabinets. Are there specific tips for cutting or adjusting the modules? Do you use shelves under the sloped ceiling, incorporate support beams or modifications? Or do you work with custom-made solutions to fit the cabinets smoothly into the slope?
What are your best advice and experiences regarding installation, stability, and appearance of Metod cabinets under sloped ceilings? I want to avoid the cabinets looking too cramped or ending up unstable.
Thanks for your tips!
Klodeniz63 schrieb:
How do you treat the cut edges on your cabinet fronts to keep them looking good?For me, it was important because I had to bevel at mid-height – I used edge banding film specifically made for wood. After some practice, it works really well, and it’s hardly noticeable that the fronts were cut.
Otherwise, sanding, primer, then paint – this also protects against moisture.
Klodeniz6318 Jul 2020 08:09One last question from me: How did you plan the height of the cupboards under the sloped ceiling to ensure there is still enough storage space, but nothing hangs too low or becomes a safety hazard? Are there any general guidelines or typical measurements you would recommend?
Good question! I would recommend first measuring the head height, meaning how high you can stand safely in front of the cabinet.
As a rough guideline:
- At around 140-150 cm (55-59 inches) room height, the cabinet should no longer protrude
- For room heights under 130 cm (51 inches), it’s better to choose open shelves or low cabinets
This depends heavily on the room, but safety and ergonomics should always be the top priorities.
Linavin schrieb:
I would recommend first measuring the headroom, that is, how high you can stand in front of the cabinet without risk.That’s exactly how I did it as well. It’s also helpful to use boxes or cardboard to simulate how tall the cabinet carcass will be before cutting everything.
