ᐅ How can I install BILLY shelves in rental apartments without using a hammer drill?
Created on: 16 May 2019 10:03
Boan9
I’m facing the following issue: I want to mount several Billy shelves from IKEA on the wall in my rental apartment, but I don’t have a hammer drill. Since I can’t just start drilling (because of the rental agreement and not owning a hammer drill), I am looking for reliable ways to securely and stably install the shelves without damaging the wall or violating any rules.
Are there alternative fixing methods, such as special anchors or other mounting techniques, that work well with standard drywall or concrete walls? I’m also interested in experiences with mounting rail systems or innovative solutions!
Thank you in advance for your tips and advice!
difepeo
16 May 2019 15:03
Boan9 schrieb:
Are there any other mechanical fasteners I can install without a hammer drill?
First of all: When using anchors and screws without a hammer drill, the wall structure is often not sufficiently penetrated, which increases the risk of reduced load-bearing capacity.
Mechanically secure alternatives without a hammer drill are therefore very limited.
One approach could be to supplement the shelves with floor supports that transfer the weight to the floor and reduce the load on the wall.
In addition, mounting systems that use compression anchors (e.g., tension columns) are an option; they avoid wall damage but tend to be relatively expensive and sometimes less aesthetically pleasing.
Please carefully consider the risk, as liability can become an issue in case of damage due to inadequate fastening.
ixlu1
17 May 2019 09:45
Hello Boan9,
I find this topic really interesting! 🙂
What I can recommend is using these metal mounting rails (so-called "French cleats") that you attach to the sides of the shelf and to the wall.
The great thing about them: the cleats are fixed with regular screws (possibly with wall plugs for drywall), and you can simply hang the shelf. If you don’t have a hammer drill, a good cordless drill plus suitable wall plugs works surprisingly well.
They are very stable, flexible, and you can easily remove the shelf when moving. Definitely give it a try, it’s fun!
Good luck, and feel free to reach out if you want to know more!
This will be great!
Isabel
17 May 2019 13:11
ixlu1 schrieb:
The cool thing is: the cleats are attached using normal screws (possibly with plugs for drywall)
That is correct.
However, you need at least a good, powerful drill, depending on the type of wall. Without a hammer drill, it will be difficult in concrete walls. For drywall, this works well with appropriate cavity anchors.
If you don’t have a hammer drill, always check the fastening options for your wall type.
No hanging system can replace a solid anchoring when heavy loads need to be supported.
