ᐅ How can I improve the stability of IKEA Metod cabinet joints?
Created on: 7 Jul 2022 08:17
Clintnau
Clintnau
7 Jul 2022 08:17
Hello everyone, I assembled a Metod kitchen cabinet from IKEA and am not entirely satisfied with the stability of the connections. My main concern is how to improve the connection points between the individual modules and the adjustable feet so that the cabinet is less wobbly overall and more durable. The original dowels and cam-lock system don’t seem optimal for my needs, especially if higher loads are expected or multiple cabinets are joined together. Are there any recommended tricks, reinforcements, or alternative methods to reliably increase stability at these connection points? I’m particularly interested in long-lasting solutions and whether the necessary tools or additional materials can be found at IKEA or at a hardware store. Looking forward to your experiences and tips!
glapu
7 Jul 2022 09:42
Hello, I would recommend tightening the screws at the joints and applying wood glue into the dowel holes. This will increase stability. Additionally, metal angle brackets from the hardware store can be used if you want to discreetly reinforce the back panels of the cabinets.
Gafiel
7 Jul 2022 11:05
Hello Clintnau, I can understand your question well, as the stability of Metod cabinets is often a challenge, especially when dealing with heavy loads or multiple connected units. Basically, I would recommend working very precisely during assembly:
- The dowel holes must be perfectly aligned; small deviations can later cause play and thus instability.
- The cam lock system is sufficient if the connections are made correctly, but to reinforce them, you can apply wood glue into the dowel holes before inserting the dowels.
- A very effective measure is also to secure the connections additionally with small screws, for example, specifically at the back panels, if the design allows.
- Use high-quality screws that are not too short but also do not protrude.
- Connection brackets or metal plates on the back significantly increase stability without affecting the appearance.
I would be interested to know what kind of loads you are experiencing specifically and whether you often move or rearrange the cabinets – this can influence the appropriate reinforcement.
Elias
7 Jul 2022 12:31
I completely understand that stability is important to you, especially when the cabinets have to withstand everyday use. I felt the same way and was a bit worried at first that the joint might give way. What helped me was lightly applying wax or talcum powder to the cam lock fittings before locking them in, which creates a tighter fit. I also put wood glue into the dowel holes, which gives me some extra peace of mind. I'm still unsure about using metal brackets for reinforcement, as I don’t want to affect the appearance. Are there any discreet options for that? This has really been on my mind – it’s great to be able to share and discuss it here.
gojan7
7 Jul 2022 14:23
Just make sure that all parts fit together cleanly and that the screws are properly tightened. Apply glue to the wooden dowels; do not overtighten the cam locks. For increased stability, metal brackets at the corners are the best solution.
Ramon4
8 Jul 2022 07:11
Hello Clintnau, I understand your concerns well. The connections with Metod are designed for normal use, but if you are looking for more robust solutions, here are some tips:
- In addition to the IKEA methods, connect the cabinets with sturdy metal connectors or turnbuckles that you can find at hardware stores.
- For the legs, you can use more stable, height-adjustable alternatives instead of the original ones to reduce wobbling.
- Use wood glue on dowels as recommended, as it permanently strengthens the joint.
- Important: Always assemble the cabinets on a level floor, as uneven floors significantly weaken the overall structure.
If you have more details about a specific connection area, feel free to share!
