ᐅ How can I improve the stability of IKEA Metod cabinet joints?
Created on: 7 Jul 2022 08:17
Clintnau
Hello everyone, I assembled a Metod kitchen cabinet from IKEA and am not entirely satisfied with the stability of the connections. My main concern is how to improve the connection points between the individual modules and the adjustable feet so that the cabinet is less wobbly overall and more durable. The original dowels and cam-lock system don’t seem optimal for my needs, especially if higher loads are expected or multiple cabinets are joined together. Are there any recommended tricks, reinforcements, or alternative methods to reliably increase stability at these connection points? I’m particularly interested in long-lasting solutions and whether the necessary tools or additional materials can be found at IKEA or at a hardware store. Looking forward to your experiences and tips!
Elias schrieb:
I’m still unsure about reinforcements with metal brackets, as I don’t want to affect the appearance.I know that feeling very well—the concern about damaging or visibly altering something is often there. Perhaps a method of attaching the brackets from the inside to the back panel could help. This way, they remain out of sight but still provide additional stability. I reinforced my Metod cabinets like this and now feel more confident.Also: Good preparation is worthwhile. When the dowels and cam locks fit tightly, you immediately notice an improvement in the overall quality during assembly. It also helped me to carefully smooth the holes with fine sandpaper before assembly if they weren’t perfectly clean.
A tip from me: If you don't tighten the screws in the cam locks completely at first, you can make adjustments afterward. Apply glue into the dowel holes and then tighten the screws a bit more firmly. This helps prevent a loose fit. It's also a good idea to secure the joints with clamps while the glue is drying.
Gafiel schrieb:
I’m interested in which specific loads you experience and whether you frequently move or rearrange the cabinets – that can affect the proper reinforcement needed. Thanks for asking, Gafiel, I can explain in more detail: The cabinets are mainly intended to store kitchen utensils, some of which are quite heavy, such as cookware and spice jars. Additionally, I plan to connect several modules to form an L-shaped arrangement. The cabinets will be moved only rarely, but they need to withstand continuous load and also not wobble or tip when leaning on them or under short-term pressure. That’s why I’m curious whether the original fasteners should be replaced or supplemented with stronger screws or metal brackets, or if glue and the original screws are sufficient for a permanent hold.
