ᐅ What repair options are available for loosening screws in BILLY?
Created on: 16 Jul 2018 09:12
noomigi
Hello everyone, I have an issue with my Billy shelf where some screws keep loosening over time. Although the shelf usually stays in one place, frequent opening of the doors and the weight of the books seem to cause the screws to gradually come loose. I’m very interested in knowing what repair options are available to permanently secure these loosening screws on the BILLY shelf. Are there proven methods or materials that specifically work with this IKEA furniture without compromising its stability or damaging the wood? I look forward to your tips and experiences!
cassandra
17 Jul 2018 09:15
Regarding alternatives, there are also twisted beech screws, known as tension screws, which provide better holding power in wood due to their threading. They are somewhat more complex to install but offer significantly greater stability with a secure fit compared to standard chipboard screws. The downside: For Billy, additional suitable holes or modifications would be required, making assembly more complicated.
Dwight49
17 Jul 2018 10:02
Another practical method for tightening loose screws is to fill the drill holes with wood shavings mixed with wood glue. Once dry, this creates a solid base that holds the screw firmly in place. This technique is cost-effective and preserves the original structure. It is especially suitable for minor damage or when you want to avoid significant alterations to the furniture.
Taubi
17 Jul 2018 10:21
Mix wood chips with glue and fill the hole with the mixture, exactly. After that, you can screw the screw back in. This method worked well for me.
noomigi
17 Jul 2018 11:00
Thank you for the many helpful contributions!
To summarize, I now have several practical approaches: wood repair kits for damaged holes, using wood shavings with glue, installing metal brackets for additional stability, and the option of pre-treating screws with plastic washers or light wax.
Does anyone have an opinion on the long-term effectiveness of any of these methods? I am especially interested in which of these holds up best under continuous load from books and frequent use.
PULAU
17 Jul 2018 11:33
noomigi schrieb:
Which of the methods holds up best under permanent load from books and frequent use.
For permanent load, I recommend combining wood repair kits with metal brackets. The wood repair kit restores internal strength, while the metal brackets significantly increase mechanical stability. This dual approach minimizes the risk of screws becoming loose again.
theota
17 Jul 2018 12:05
I also consider this combination the best compromise.
TOSAN schrieb:
Make sure the screws are not too long, otherwise they can go through the board.
This is definitely something to watch out for, otherwise you might end up with unsightly spots or safety hazards. Also, some cheap angle brackets are so thin that they hardly provide any stability. It's best to use somewhat sturdier ones – but not too large, so they remain discreet.
