ᐅ How can I identify damaged screws in IKEA Metod cabinets and replace them?
Created on: 12 Feb 2020 09:17
Stuartru
Stuartru
12 Feb 2020 09:17
Hello everyone, I have assembled a Metod kitchen system from IKEA and noticed during the build that some screws appear to be damaged or worn. My specific question is: How can I reliably identify damaged screws in IKEA Metod furniture without compromising the materials or structural stability? Are there particular signs to look for during a visual inspection or common types of damage that occur? And if my suspicion is confirmed, what is the best way to replace these screws? I would also like to know if IKEA provides suitable replacement parts directly and whether I need to pay attention to specific screw types or measurements. Thanks for any helpful and practical advice.
jokau
12 Feb 2020 09:45
Damaged screws can be identified by noticeable deformations on the head or thread, such as frayed edges or rounded screw heads. When replacing them, you should pay attention to the original dimensions – diameter, length, and thread type must match. Replacement screws are usually provided free of charge by IKEA; simply request them there with the article number and proof of purchase.
Danabla
12 Feb 2020 11:29
To identify damaged screws in IKEA Metod systems, I recommend a visual inspection based on the following criteria:
- Worn screw heads that no longer grip the screwdriver
- Bent or distorted screws
- Damaged or missing threads
- Signs of corrosion
These issues may compromise stability or make assembly more difficult.
For replacement: IKEA usually offers spare screws through customer service. It is important to use exactly the same screws, as Metod uses standardized fittings. It is best to note down or take a photo of the screw along with its packaging and reference (e.g., instruction manual) and specifically request a replacement. Alternatively, you can obtain screws with the same dimensions and material properties from specialized suppliers if the originals are not available.
JONKO
13 Feb 2020 14:03
That’s true, and I have personally experienced how unstable kitchen furniture can become when using the wrong screws. One screw broke while tightening, which created so much instability that I had everything rechecked. I can only recommend not just checking for visible damage but also carefully testing whether the screws are still firmly seated without being overtightened.
jokau schrieb:
You can identify damaged screws by obvious deformations on the head or thread
That’s a good point since sometimes tiny cracks or small dents only become visible when you slightly move the component. Safety feels different, so it’s better to check one time too many than too few.
Mufato
14 Feb 2020 08:26
Stuartru schrieb:
Are there any specific signs to look for during a visual inspection or typical damage that appears?
Yes, the following points are common:
- Screw head rounded off or damaged
- Threads no longer intact, e.g., worn down
- Visible rust or oxidation
- Screw is loose or wobbles
For replacement, simply bring the original screw to the Ikea service or order the spare part. There are also sets with replacement screws for Metod if you want to be on the safe side.
Make sure to use the correct tools to avoid damaging new screws again.
