ᐅ How can I remove scratches from Ikea HEMNES furniture?
Created on: 2 Jul 2023 18:37
U
Uspra
U
Uspra
2 Jul 2023 18:37
I have several Ikea Hemnes furniture pieces in my living room, including dressers and nightstands, mostly made of painted solid wood. Unfortunately, over the past few months, some scratches have appeared in visible areas. These are not just superficial marks but sometimes somewhat deeper dents that noticeably affect the appearance. My question to the community is: How can I remove scratches from Ikea HEMNES furniture as gently and effectively as possible without damaging the surface?
I like to use products suitable for wood but don’t want to try something that might cause more harm than good. Are there proven methods—perhaps special polishes, creamy care products, or home remedies—that can repair or significantly reduce the appearance of scratches?
Also, I’m interested in whether deeper scratches require additional repair steps, such as sanding or repainting. I look forward to your tips on what has worked well in everyday use, especially with HEMNES furniture.
Thank you in advance!
barle
2 Jul 2023 19:12
Uspra schrieb:
How can I gently and effectively remove scratches from Ikea HEMNES furniture without damaging the surface?
Try first using a furniture wax designed for painted wood surfaces. It works well to conceal minor scratches. For deeper scratches, there are wood repair kits with wax sticks that usually match the colors of HEMNES furniture quite well. Avoid sanding without experience, as it can make things worse.
Fitigu
3 Jul 2023 08:47
The HEMNES series is mostly made of painted pine wood. Generally, minor scratches can be treated with a high-quality furniture polish that has protective and filling properties. Products containing carnauba wax or special micro-particles are suitable because they visually even out imperfections without damaging the finish.
For more noticeable scratches, a two-step process is recommended:
- Clean the affected area with a neutral furniture cleaner without solvents
- Then apply an appropriate wood repair stick or wax filler to match the color
After drying, apply furniture polish to restore shine and protection to the surface.
Sanding or repainting should only be done for really deep, large-area damage, as it is often difficult to exactly reproduce the original IKEA finish.
Palenar
4 Jul 2023 10:23
Fitigu schrieb:
For more noticeable scratches, a two-step approach is recommended:
That sums it up well, but I’d like to go into more detail, as the treatment strongly depends on the type and depth of the scratch.
For painted HEMNES furniture, the clear coat layer is important: minor surface scratches usually only affect the clear coat, sometimes caused just by dirt, and can be removed with polishing agents or microfiber cloths. It’s best to work gently here, for example using a polish that contains fine abrasives.
Deeper scratches are more challenging, as they reach down to the wood surface. In this case, the following steps should be observed:
- First, clean the surface with a damp cloth and allow it to dry completely
- Using colored wax sticks matched to the wood tone is useful to even out the color and fill the scratches
- Then, ideally apply a special clear lacquer for pine wood with a small brush to renew the protective layer
I also recommend testing first on an inconspicuous spot to check if the clear lacquer matches in color and if the wax stick is not too dark or too light.
Alternatively, repair kits from furniture retailers often include a complete small application guide.
Could you please describe approximately how deep your scratches are and if you have already tried any methods? That would help give more targeted advice.
