I have had an IKEA Malm bed frame for some time now, and unfortunately it has started to creak more and more whenever someone moves or sits down on it. This is quite annoying, especially at night, because the noise is really loud and unpleasant.
My question: How can this Malm bed frame be repaired or treated to completely eliminate the creaking? I have read that it might be caused by the joints or screws, but what are the recommended systematic steps to address this?
Are lubricants like WD-40 sufficient, or are more substantial measures needed, such as tightening screws, replacing wooden slats, or adding padding? Are there any specific tips tailored to the design of the Malm bed frame?
I would appreciate concrete suggestions, ideally with practical advice on what to watch out for to make the bed frame noise-free again in the long term.
Dilen schrieb:
Are there any signs of wear on the wooden parts of your model?That is exactly what I wanted to emphasize.
It is often overlooked that the materials used and the build quality of IKEA furniture can vary. With cheaper particleboard, wear caused by moisture or constant stress is a common concern.
I think it’s important to carefully examine the construction instead of just reaching for a quick WD-40 fix.
Has farta already checked how old the bed is and whether the parts are still undamaged?
For solving squeaking Malm bed frames, I recommend the following structured approach:
- Loosen all screws and inspect the threads for wear.
- Clean wooden joints (remove dust and residues).
- Use wood filler for damaged drill holes.
- Apply appropriate furniture lubricants or dry graphite powder to wooden surfaces and metal connections.
- Tighten screws with a torque wrench according to the manufacturer's specifications to avoid material damage.
- In case of significant wood wear, replace damaged parts or decouple them using sealing tapes.
This methodical approach ensures that you address not only the symptoms but also the root cause, securing long-term stability.
Maria35 schrieb:
This methodical approach ensures that [...] cause and long-term stability are secured.I fully agree with this. Allow me to add a technical perspective:
The squeaking is caused by microscopic friction movements at the joints, which are intensified by repeated load changes.
Therefore, in addition to retightening screws, it is advisable to pay attention to load distribution as well, for example through additional supports or edge protection, to avoid pressure peaks.
Properly applied mounting tape at contact points helps prevent unwanted movements and significantly extends the service life.
Regular inspection of connection parts and, if necessary, readjustment are also part of a sustainable repair approach.
