I have had an IKEA Malm bed frame for some time now, and unfortunately it has started to creak more and more whenever someone moves or sits down on it. This is quite annoying, especially at night, because the noise is really loud and unpleasant.
My question: How can this Malm bed frame be repaired or treated to completely eliminate the creaking? I have read that it might be caused by the joints or screws, but what are the recommended systematic steps to address this?
Are lubricants like WD-40 sufficient, or are more substantial measures needed, such as tightening screws, replacing wooden slats, or adding padding? Are there any specific tips tailored to the design of the Malm bed frame?
I would appreciate concrete suggestions, ideally with practical advice on what to watch out for to make the bed frame noise-free again in the long term.
farta schrieb:
It annoys me quite a bit, especially at night, because it is really loud and unpleasant.I wonder if the squeaking is actually caused only by the screws or by the wood itself. Often, furniture made from particleboard or veneered materials tends to loosen slightly at the joints over time.
Before using lubricants: Have you checked if the screws are really tight? That often helps more than expected.
farta schrieb:
Are lubricants like WD-40 enough, or are more solid measures like retightening screws better...WD-40 can help, but it may also damage the wood or the surface. A dry lubricant like graphite powder might be better if the noise comes from wood-on-wood contact.
It’s also important to clean the area around the joint thoroughly to ensure no dust or dirt remains, which could act as an abrasive surface.
Hi, farta!
I completely understand how annoying those squeaking sounds at night can be. 🙂
I once had a similar problem with an IKEA bed and did the following:
First, I loosened all the screws completely, then carefully tightened them again—not too tight, to avoid damaging the wood. Then I applied furniture wax to the contact surfaces, which really reduced the squeaking a lot.
Give that a try; it’s an easy “home remedy” before considering more complicated solutions. :-)
By the way: Have you checked whether the cross slats might have some movement? That could also be a possible cause.
To completely eliminate the squeaking, it is recommended to follow the individual steps thoroughly and systematically.
1. Loosen the screws and check the threads for any damage. Replace any defective screws.
2. Inspect all connection points for proper alignment – sometimes a part may be slightly misaligned, causing pressure marks.
3. Remove the slatted frame and clean the support surfaces. Then treat them with furniture wax or beeswax to reduce friction.
4. Wooden strips can be isolated using special felt or foam rubber pads to dampen vibrations.
5. For mechanical connection points, it is advisable to use thread-locking compound to prevent loosening.
Additionally: Please check whether the bed is standing on an uneven floor, as movements in the structure itself can also cause noises.
Are there any signs of wear on the wooden parts of your model? This would be important for potential replacement.
To add to this, I would like to point out that the cause of the squeaking can be quite varied.
Not only the screws themselves but also the metal connectors or fasteners may need to be lubricated again.
If the bed frame is older, the drilled holes can become enlarged. In such a case, you can fill the holes with wood shavings or toothpicks coated in wood glue and then retighten the screw. This will restore a firm hold.
I also recommend being gentle when retightening the screws and avoiding excessive force to prevent damaging the threads in the chipboard.
Good luck testing these tips!
