Hello everyone, I have been experiencing a problem for some time with my IKEA Brimnes drawer chest where several drawers squeak unpleasantly when opening and closing. These are wooden drawers with metal runners. The noise is likely caused by friction or lack of lubrication, but I have not found any loose screws, and the drawers are not misaligned. My specific question is: How can I effectively and permanently eliminate the squeaking in the Brimnes drawers? Are there any special materials or techniques that have proven helpful without having to remove or replace the entire set of runners? I look forward to your tips and experiences so I can finally get rid of the noise.
I agree that silicone spray is usually the best choice since it leaves no residue and does not become sticky. Candle wax works well at first but can cause dusty deposits over time. Because the tracks are generally easily accessible from the outside, removing the drawer is not always necessary. However, to clean thoroughly and apply lubricant more effectively, it is recommended to remove the drawer if possible.
If the squeaking is caused by damaged plastic glides, replacement glides are available and relatively easy to install. This is worth doing if smooth operation does not return.
A precise way to eliminate squeaking in IKEA Brimnes furniture is to inspect and clean the sliding rails for any sticky particles. It is essential to have a clean surface before applying lubricant to avoid mixing the lubricant with dirt, which would otherwise increase friction. Silicone spray or dry lubricants based on PTFE provide optimal sliding properties.
Simple wax can help temporarily but is less effective in the long term, as it usually does not offer the same lubricating qualities as modern sprays and tends to attract dirt.
The guide rails do not necessarily have to be removed, but only by dismantling can all surfaces be thoroughly cleaned and inspected. Therefore, I recommend at least removing the drawer if you don’t mind the extra effort.
In conclusion, cleaning, using high-quality lubricants, and, if necessary, replacing the plastic glides are the methods that ensure the best durability.
I understand how annoying that squeaking can be. For me, it helped to start with some simple methods and then improve them systematically. One thing people often forget is that even a slightly misaligned drawer can cause friction noises, even if it’s not immediately visible.
So it’s worth checking whether the drawer is running parallel and, if necessary, tightening the screws.
I also find the tip about using silicone spray very useful because it not only lubricates but also prevents dust from sticking. If you’re unsure, try it first on the outside of a guide to see how the product reacts. Patience is really important here—you need to apply it thoroughly.
I hope you find the solution that works best for you.
