Hello everyone, some time ago I assembled an Ikea Platsa piece of furniture, but I noticed that some screws gradually become loose. Additionally, the material around the screws seems to chip away slightly, which affects the stability. My question is directed to those who have had similar experiences or know the best way to address this problem: How can you effectively fix loose screws in Ikea Platsa furniture without causing further damage to the material? Are there specific techniques, materials, or tools that should be used to ensure a long-lasting fastening? Any advice on prevention would also be greatly appreciated. Thank you in advance for your tips!
FABIAN_DEO18 Aug 2016 07:53Hello Makslo, I am familiar with your issue of loose screws in Ikea Platsa units, as the material at the fixing points is often made of particleboard, which can deteriorate over time due to stress and repeated assembly. To fix this problem effectively, I recommend a systematic approach:
- Fully unscrew the screws and clean the holes to remove old wood chips and dirt.
- If the holes are already frayed or damaged, you can fill them with wood glue and small wooden dowels or toothpicks. It is important to let the wood pieces dry completely before reinserting the screws, for at least 24 hours.
- Alternatively, in particularly critical areas, you can use special wood repair fillers that can be sanded after curing and drilled for re-screwing to restore load-bearing capacity.
- Sometimes using slightly longer screws is helpful if the wood anchoring needs to go deeper for better stability. Be careful not to use screws that are too long and could damage other furniture parts.
- Washers can also be useful to better distribute the load and relieve the wood.
One more tip: before reinserting the screws, it is advisable to lightly coat the threads with wax or soap to allow smooth screwing and prevent cracks.
Have you ever worked with wooden dowels or repair fillers? If you describe more precisely where the screws are loose, I might be able to suggest more specific solutions.
FABIAN_DEO schrieb:
To solve this problem permanently, I recommend a structured approachExactly, that sums it up well! I would like to add that with furniture made from particleboard or similarly pressed materials, it is very important not to overtighten the screws in order to avoid further damaging the material. If the screws have already loosened, the material usually already has some weakness.
From my own experience, I recommend:
- Filling the damaged screw holes with wood filler or small wooden pieces, then allowing them to dry thoroughly.
- Carefully screwing in hex key (Allen) or Phillips screws using a torque wrench (or by having a good feel for the torque).
- Additionally, you can reinforce the holes with small plastic threaded inserts inserted into pre-drilled holes – however, these require a drill and some DIY skill.
The goal is to distribute the force evenly over the material and avoid overloading. Also, you should occasionally check the furniture, especially if it is under load, and retighten the screws, but without applying excessive force. Did you feel that the screws were too tight or too loose when you assembled your furniture?
