ᐅ How can I fix loose screws in IKEA Metod kitchen cabinets?
Created on: 21 Mar 2015 07:26
katibla
katibla
21 Mar 2015 07:26
Good morning everyone, I occasionally have the problem that screws in my IKEA Metod kitchen cabinets loosen over time, causing the furniture to feel unstable. This happens especially with the hinge systems and the connection points of the cabinet bodies. My question is: How can I professionally and permanently fix or tighten loose screws in IKEA Metod kitchen furniture without the screws loosening again shortly after or damaging the material? Are there any special techniques or tools recommended for this? I want to avoid unnecessary damage because I want to use the cabinets for as long as possible.
harold
21 Mar 2015 08:42
Hello katibla,
your issue is quite common with kitchen cabinets of this type since the connection points are often made of particleboard, which can get damaged if screws are overtightened or frequently retightened. Here are some tips on how to properly repair and secure the screws:
- Tighten screws by hand only, then if needed, retighten with a torque of max. 3 Nm (2.2 ft-lb) to avoid overloading the material.
- For loose screws in shelves or back panels, use wood glue combined with small wooden dowels or cork pieces to reinforce the screw hole.
- For hinges, sometimes inserting small plastic inserts (very thin heat shrink tubing can work as a substitute) helps.
- Another proven method is using medium-strength threadlocker to prevent screws from loosening due to vibrations.
- Most importantly, check if the screws have the correct length and diameter—too short or too thin screws are often the cause of the problem.
If you want, I can also explain how to fill damaged holes if you are already facing major issues with the screws. Just let me know!
katibla
21 Mar 2015 09:10
Thanks for this idea, it sounds like a solid method. I’m just wondering if it’s practical to apply this to fully assembled cabinets without removing them? Especially with hinge screws, which are often difficult to access. Are there any tricks to repair these directly on the assembled furniture? Or would it be better to remove the cabinet first and then reinforce the holes?
O
ONCARTER
22 Mar 2015 06:15
An extension is advisable if you want to achieve a permanent repair. Especially with the Metod series, the interior is usually designed so that removing the door or cabinet body is relatively straightforward.
Brief overview of the procedure:
- Unhinge the door, unscrew the hinges
- Remove any loose screws
- Clean the screw holes thoroughly
- Fit wooden dowels or cork pieces with wood glue (trim slightly if necessary)
- Allow the wood glue to dry completely (at least 24 hours)
When the unit is installed, you can usually only tighten screws slightly, but reinforcement is not permanently possible.
Also important: regularly check the screws after the repair to detect any new looseness early.
pintra
22 Mar 2015 08:09
I always think it’s best not to take everything apart right away – you learn to treat those beloved kitchen cabinets with a bit of patience 🙂
For cases where you don’t want to remove the screws, I like to use small plastic or rubber washers under the screw heads. This helps prevent the screws from feeling too loose and absorbs some vibration that would otherwise cause them to loosen.
Also: a little assembly paste or adhesive applied directly to the screw can work wonders – just make sure it’s not a hard adhesive, so the screw can still be removed later. This way, the furniture stays stable, and you can avoid major repairs. 😊
Sepele
23 Mar 2015 10:33
katibla schrieb:
I’m just wondering if it’s even feasible to do this on fully assembled cabinets without removing them? Especially with hinge screws, which are often hard to reach.
In general, I always recommend at least partially dismantling the furniture for repairs. That’s the only way to achieve a professional fix.
However, if removal isn’t possible, try the following:
- Carefully unscrew the screw
- Stabilize the screw hole with a toothpick or small wooden dowel and wood glue
- Apply medium-strength threadlocking adhesive to the screw
- Gently screw it back in
This method usually provides only a temporary hold but is often the best option without removal.
A permanent repair is only possible by removing the furniture and, if necessary, reinforcing the screw holes, as described by harold and ONCARTER.
