ᐅ How do I fix a loose Ikea Metod drawer?
Created on: 7 Feb 2021 18:22
azizja
azizja
7 Feb 2021 18:22
I have an Ikea Metod kitchen drawer that has gradually become loose over time. In other words, it no longer sits firmly on the drawer slides and wobbles slightly when pulled out or when weight is applied to the drawer. The screws and connections appear visually fine, but the drawer still seems to loosen a bit.
I suspect that either the side fixings of the drawer runners have loosened or that the sliding mechanism itself is developing play.
My question to you is: What specific steps should I take to securely and firmly fix this loose Metod drawer again? Are there any special tips or tools you would recommend for a simple yet durable repair?
Thanks in advance for your helpful advice!
pakokla
7 Feb 2021 18:45
Tighten all screws, if not done already: completely remove the drawer slides, then check if the side panels are bent. If everything is straight, reinstall the slides correctly and firmly snap the drawer back in place. In case of significant wear, it is better to get new slides.
taudi
8 Feb 2021 09:33
For repairing a loose Ikea Metod drawer, I recommend the following approach:
- Fully extend and remove the drawer.
- Check the drawer slide rails: Are the screws tight? If not, carefully tighten them, but not too much to avoid damaging the wood.
- Inspect the guide grooves for dirt or damage. Clean them and, if necessary, make slight adjustments.
- Check if the drawer side panels or bottom board are warped. This can also cause looseness.
- When reinserting, make sure the slide rails engage precisely and the drawer operates smoothly and evenly.
It is important not to use force, as this can damage the material. For worn-out drill holes, using wooden dowels or re-drilling with larger screws can help improve durability.
V
Victor54
8 Feb 2021 14:26
azizja schrieb:
The screws and connections look fine visually
Just because the screws appear intact does not mean they still provide sufficient support. Drill holes in chipboard material often loosen, causing screws to lose grip even without visible damage.
pakokla schrieb:
Tighten all screws
This is generally a good idea, but if the cabinet material around the screws is softened or damaged, tightening will only provide a temporary fix. An assessment should be done to check whether the wood in the fastening areas is still solid.
I recommend carefully inspecting the material at the attachment points before attempting any repairs. A lasting repair is usually only possible if damaged screw holes are restored using wooden dowels or special repair techniques. Additionally, it should be checked whether the drawer slides still fit properly or have too much play due to wear.
rickey
9 Feb 2021 11:17
Victor54 schrieb:
That basically makes sense, but if the cabinet material around the screws is softened or damaged, tightening them will only provide a temporary fix.
I experienced the same issue with my Metod drawer. At first, I thought simply tightening the screws would be enough, but the wood was already somewhat worn. What helped me was loosening the screws, filling the holes with wood wool and wood glue, and after it dried, inserting new, slightly thicker screws. Since then, the drawer has stayed stable.
I know it sounds a bit time-consuming at first, but with some patience, many repairs can be done yourself without immediately calling a professional. Good luck and keep your spirits up – you can do it!
