ᐅ How do I fix a misaligned Ikea Metod kitchen cabinet door?
Created on: 19 Sep 2022 11:37
DANEGA
DANEGA
19 Sep 2022 11:37
I recently installed an Ikea Metod kitchen cabinet door, but it’s not hanging correctly. The door is noticeably crooked, which is especially obvious when closing—it sticks at the bottom and protrudes at the top. I have already checked the three adjustment screws on the hinges, but I’m not sure exactly how to proceed to straighten the door properly.
My question is: How can I adjust the hinges on an Ikea Metod kitchen cabinet door to realign it so that it sits straight and flush again?
Are there any special tips or things to watch out for to prevent this problem from happening again? I would appreciate a detailed and practical guide, including advice on what to avoid.
Thanks in advance!
COLEBAR
19 Sep 2022 12:18
first, check the position of the hinges on the cabinet box. You can adjust the top and bottom screws horizontally to align the door sideways. The middle screw allows you to set the depth, meaning how closely the door fits against the cabinet frame.
If the door sticks at the bottom, slightly lift the lower hinge points or loosen the screws and readjust.
PAREL
19 Sep 2022 15:54
Hello DANEGA,
I would like to explain the topic in a more systematic way and give you a guide on how to properly adjust a crooked Ikea Metod kitchen cabinet door:
- First, make sure the cabinet is fully leveled and that the carcass itself is straight; otherwise, adjusting the door will not be effective.
- Ikea hinges have three adjustment screws:
- The top and bottom screws control the horizontal alignment, meaning they shift the door left or right.
- The middle screw controls the depth, ensuring the door sits flush with the cabinet front.
Procedure:
1. Open the door and slightly loosen the horizontal screws.
2. Visually align the door straight and then tighten the screws again.
3. Now check the gap to the adjacent door or to the cabinet front, and adjust the depth with the middle screw.
Be careful not to overtighten the screws, as this can lock the adjustment.
A common mistake is to adjust the door only with the middle screw – this quickly causes the door to become crooked. It’s always a combination of all three screws.
If your cabinet floor or top is crooked, you should correct that first, otherwise adjusting the door makes no sense.
I hope this helps you.
Alberto51
20 Sep 2022 08:27
PAREL schrieb:
Be careful not to overtighten the screws to avoid locking the adjustment.
I completely agree. I initially had the same issues and was quite frustrated because the door stayed slightly misaligned despite multiple adjustments. Patience and a delicate touch during the adjustment process are very important.
Sometimes it feels like working in the dark, but with calmness and careful checks, you can really get it right.
Another tip: If the door sticks, also check whether the hinge on the cabinet is properly positioned and if there are any foreign objects or wood shavings in the way. That helped me a lot back then.
Keep going!
RETRAVIS
21 Sep 2022 17:03
DANEGA schrieb:
How can I specifically adjust the hinges of an Ikea Metod kitchen cabinet door to make the door straight and flush again?
To fix a misaligned Ikea Metod door, systematically adjusting the three screws on the hinge is essential:
- Horizontal screws (top and bottom): Adjust the lateral alignment of the door. If the door is shifted left or right, adjust these screws individually.
- Depth adjustment (middle screw): Controls the gap between the door and the cabinet front, important for flush closing.
- The vertical height of the door is usually not adjusted directly via the hinges but rather by readjusting the cabinet carcass or, in more complex models, using specific screws on the hinge.
In practice, I recommend removing and rehanging the door at least twice, checking the door’s closing between adjustments.
Also, avoid overtightening the screws, as this can make fine-tuning difficult or damage the hinge.
Conclusion: Proper adjustment requires a systematic approach, patience, and multiple fine-tunings.
