ᐅ How can I equip IKEA BESTA units with casters to achieve maximum flexibility?
Created on: 24 May 2024 09:23
Tolosu
I want to equip my IKEA BESTÅ shelving unit with casters to ensure maximum flexibility in use and positioning. The unit should be easy to move but remain stable and able to support weight. It is important to me to find suitable casters that fit well with the design and can roll smoothly on different floor types, such as hardwood and carpet.
My questions are:
- Which types of casters are recommended for BESTÅ?
- What is the best way to mount the casters without damaging the unit?
- Are there specific technical details or dimensions I should consider?
- What has been your experience regarding stability and durability when using casters on BESTÅ?
I look forward to your knowledgeable tips and practical advice to make the shelving unit as mobile as possible.
Thank you in advance!
Davidleo
26 May 2024 07:13
Great discussion here! 😊 I really like how detailed your conversation about casters is.
I fitted my BESTÅ with casters and can only say: Make sure to use locking brakes! Otherwise, you’ll always feel like the furniture is moving on its own 😅. There are also some really great designs that visually match the simple style of BESTÅ.
Even with casters added, the shelf looks light and not overloaded. It’s a great opportunity to easily move fruit crates or seasonal decorations when needed. Super practical!
Jeanbar
26 May 2024 11:22
Hello Tolosu,
if you want maximum flexibility with the casters for your BESTÅ, you should also consider whether to use lockable swivel casters or fixed casters. Lockable casters are useful if the shelving unit is often meant to stay in one place.
Another important point: When drilling for caster installation, pay attention to the load-bearing capacity of the material and avoid placing screws too close to the edge to prevent tearing out. If the original base panel is too thin, it is worth adding a wooden backing before installation to increase stability.
A question for you: Do you plan to move the BESTÅ completely often, or only relocate it occasionally? This will slightly affect your choice of casters.
In general, there is a wide range of casters available that also match IKEA furniture well in color and style. No worries, this works out nicely!
