ᐅ How can I effectively protect Ikea Besta units from moisture in the bathroom?
Created on: 14 Dec 2020 10:03
SANNAU
SANNAU
14 Dec 2020 10:03
I am planning to use the Ikea Besta system in the bathroom, but I am unsure how to best protect the furniture from moisture. These units are originally not designed for bathroom use, and I want to avoid swelling or permanent damage due to high humidity and splashes.
I am particularly interested in long-term and practical solutions, possibly including additional impregnation or special coatings that can be applied to the wood or edges. Are there any experiences on how to make the Besta system water-resistant, or is it better to invest in different furniture right away?
How do you use your Besta furniture in the bathroom, and what measures have you taken to effectively protect it from moisture and potential damage?
I look forward to your tips and experiences!
WARREN
14 Dec 2020 10:45
I would recommend not placing the Besta furniture directly on the floor, but rather using feet or support plates. Additionally, good ventilation in the bathroom is helpful, especially after showering. You should avoid splashing water, so try not to place the furniture directly next to the shower.
mo-hau
14 Dec 2020 11:13
It should be noted that the Ikea Besta system is primarily designed for dry indoor areas and therefore does not have a true moisture resistance rating. To effectively protect the furniture from moisture in bathrooms, the following measures may be useful:
- Sealing edges and surfaces with a special moisture-resistant varnish that repels water
- Using waterproof sealing tapes at joints
- Mounting on spacers to avoid direct contact with moisture and puddles on the floor
- Ensuring adequate room ventilation or using a dehumidifier
To prevent water damage, care should be taken when installing lighting or electrical components in areas exposed to splashing water, and the furniture should never be left consistently damp.
pauPierce
14 Dec 2020 14:27
I’m happy to provide a more detailed assessment, as I have used a Besta cabinet in my bathroom and gained some experience. It is important to understand that Besta units are made from particleboard with a foil coating, which is especially sensitive to moisture at the edges and back panels.
Effective protection involves several steps:
- Edge treatment: At the cut edges and corners, it is advisable to apply waterproof edge protectors (e.g., made of PVC) or additionally coat the edges with a high-quality acrylic or specialized moisture-resistant paint. These areas are particularly vulnerable to water absorption.
- Surface treatment: The smooth foil coating protects against splashes but should be regularly inspected for damage. Small scratches can be repaired using special foil repair kits.
- Installation clearance: It is important that the furniture does not stand directly on the floor. Feet or shallow baseboards made from plastic or metal prevent swelling caused by standing water.
- Positioning: Ideally, the Besta system is installed on a wall not directly exposed to water splashes from showers or sinks. Alternatively, a moisture barrier layer can be installed behind the back of the unit.
- Ventilation: After bathroom use, effective ventilation should be ensured. An exhaust fan with a humidity sensor is very helpful.
Personally, I placed a waterproof PE film under the Besta unit as a protective layer to catch any water splashes underneath.
What is the humidity level in your bathroom, and how frequently does the installation site experience direct water splashes? This information would help provide a more precise recommendation.
SANNAU
14 Dec 2020 15:36
pauPierce schrieb:
What is the humidity level at your location, and how often does the installation site get exposed to direct water splashes?
Thank you for your detailed reply! After showering, the humidity usually stays around 70-75%, often for longer if there is no direct ventilation. Water splashes occur almost daily because the Besta furniture is placed right next to the sink—not directly under the shower head, but quite close.
So I understand that edge sealing and distance from the floor are more or less essential, and the ventilation needs to be improved as well.
I am considering whether an additional protective layer like a moisture-resistant paint is really sufficient, or if I should rather opt for a membrane layer. Are there materials you know of that can simply be applied on top yet still look good and remain practical?
And one more question for everyone: What about the back panel? Should it be completely replaced, insulated, or sealed? Thanks!
hauklo
15 Dec 2020 08:02
A few additional points based on my research regarding moisture protection for bathroom furniture systems:
- Whenever possible, replace back panels with materials suitable for damp environments, such as water-resistant MDF boards or specialized plastic panels. The original back panels of Besta cabinets are usually thin and not water-resistant.
- Alternatively, you can apply several coats of sealing paint or water-repellent coating to the back panel before installation to create a moisture barrier.
- For surface sealing, polyurethane (PU) varnishes are often effective. They are more durable than simple acrylic paints and provide better protection against splashing water.
- It is also important to carefully seal joints and screw holes, as moisture tends to penetrate these areas.
- If possible, the interior sides of the cabinets should be lined with a breathable yet moisture-resistant film to help balance condensation.
- Finally, I would like to mention room ventilation: in addition to an exhaust fan, a dehumidifier is recommended if the bathroom has no window. This significantly reduces the risk of moisture damage.
If someone can provide more specific information about the type of use or the installation location, I can offer more targeted advice.
