ᐅ How can I effectively clean Ikea Pax wardrobes to remove dust and pollen?
Created on: 27 Oct 2021 20:37
Tamer
Tamer
27 Oct 2021 20:37
I have a somewhat specific question about cleaning my Ikea Pax wardrobe, especially regarding dust and pollen that accumulate on the shelves and, more importantly, inside the wardrobe compartments. The Pax is partially open-designed and uses several sections with sliding doors and clothing rails. I have noticed that dust and especially pollen stick quite strongly inside during spring and eventually become really unpleasant, also concerning allergies.
So my question is:
How can I effectively clean my Ikea Pax wardrobe against dust and pollen, so that I don’t just wipe the surface of the wardrobe but also thoroughly clean the interior spaces, edges, gaps, and possibly the fabric elements? Are there any special methods, cleaning agents, or tools that have proven effective without damaging the materials or fittings? And how often does a thorough cleaning make sense for someone with allergies?
I look forward to your experiences and tips!
floga
28 Oct 2021 07:53
Tamer schrieb:
How can I effectively clean my Ikea PAX wardrobe from dust and pollen, so that I don’t just wipe the surface but also thoroughly clean the interior spaces, edges, gaps, and possibly the fabric elements? Are there any specific methods, cleaning agents, or tools that have proven effective without damaging the materials or fittings?
I can definitely understand how annoying that can be, especially if you’re allergic to pollen. I had the same issue with my PAX and tried a few things. What helped me a lot was first completely emptying it and then vacuuming with a vacuum cleaner fitted with a soft brush attachment. This way, you can reach the edges and gaps well without scratching the surfaces.
Sometimes I also used a damp microfiber cloth to wipe the surfaces—but it’s important to use it only damp, not wet, to avoid damaging the materials. For fabric elements like removable shelves, I clean them separately and let them dry thoroughly.
I find it helpful to do this kind of thorough cleaning regularly, at least every two months, and even more often in spring. You just feel better afterward. As I said, pollen is really a tough challenge, but with small steps, it can be managed.
Gregory
28 Oct 2021 15:04
Tamer schrieb:
How can I effectively clean my Ikea PAX wardrobe to remove dust and pollen, so that I don’t just wipe the surface but also thoroughly clean the interiors, edges, gaps, and possibly the fabric components? Are there specific methods, cleaning agents, or tools that have proven effective without damaging the material or fittings?
For effective and gentle cleaning of the Ikea PAX wardrobe against dust and pollen, I recommend the following step-by-step approach:
- Completely empty the wardrobe to access all surfaces.
- Use a vacuum cleaner with upholstery and brush attachments to clean all interior surfaces, edges, and top panels.
- Use microfiber cloths slightly dampened with water or a pH-neutral cleaner to carefully wipe away dirt and pollen residues.
- For fabric components (e.g., baskets or shelves with textile elements), clean according to the care instructions or wash separately.
- Avoid harsh chemicals such as ammonia or abrasive cleaners, as these can damage the melamine coating.
- For sliding doors, clean the tracks with a dry cloth and, if necessary, apply silicone spray lightly to maintain smooth operation.
Cleaning intervals of every 4 to 6 weeks are advisable, especially during pollen seasons or in environments with high dust levels. Additionally, ensure good indoor ventilation and consider air purifiers to reduce the accumulation of new dust.
GALEO4
29 Oct 2021 09:12
Tamer schrieb:
How can I effectively clean my Ikea PAX wardrobe to remove dust and pollen, so that I not only wipe the surface but also thoroughly clean the interior, edges, gaps, and possibly even the fabric elements?
I wonder if all that effort for the PAX is really necessary. Let's be honest – Ikea furniture is designed for easy use, not for professional allergen removal. Getting rid of dust? Sure, vacuuming helps.
But dealing with pollen that settles deep in cracks and sticks there—that's like fighting a losing battle. It would make much more sense to opt for airtight fronts or to organize the wardrobe in a way that prevents dust from getting in at all.
I think priorities should be: 1. Air filters or regular ventilation
2. As many closed fronts as possible
3. Minimal cleaning, because too much rubbing and damp cloths can damage the simple material.
So my point is: the more you scrub, the more you risk damaging the PAX’s material, and it doesn’t really provide effective protection against pollen either.
O
olivernu
29 Oct 2021 11:46
GALEO4 schrieb:
I think it’s better to prioritize as follows: 1. Air filtration or regular ventilation
2. Preferably closed fronts
3. Minimal cleaning, since too much friction and damp cloths can damage the simple material.
That’s a very good point that should be added to: the best cleaning is often prevention.
In addition to the structured cleaning method already mentioned, I recommend using a HEPA air filter in the bedroom if the PAX wardrobe is located there, especially for those with pollen allergies.
It is also advisable to avoid placing the wardrobe directly next to drafty windows and to control ventilation times so that as little outdoor pollen as possible enters the room.
Regarding cleaning, I further recommend using an antistatic duster or microfiber cloths. These trap dust and pollen better and prevent them from becoming airborne.
In short: regular vacuuming combined with antistatic cleaning and air quality control is an effective triple approach against dust and pollen in the PAX wardrobe.
