ᐅ How can I discreetly repair small chipped edges on Ikea Besta furniture?
Created on: 1 Feb 2022 08:37
lomeo
lomeo
1 Feb 2022 08:37
Hello everyone, I have noticed some minor damage on the edges of my Ikea Besta furniture. These are small spots where the coating has chipped off slightly, mostly on corners and edges, likely caused by bumps or minor accidents. Since I want to repair the furniture as discreetly and durably as possible, I am looking for advice on the best methods or materials to achieve a repair that is barely noticeable and ideally restores protection to the surface. Has anyone had experience with, for example, special repair kits, wood or plastic fillers, or touch-up pens? I would appreciate tips specifically related to Besta fronts or similar Ikea furniture with melamine coating.
draleo
1 Feb 2022 09:24
First, it is important to assess the damage: for chipped edges on Ikea Besta units with melamine or foil coating, repair is recommended using a color-matched repair pen or marker suitable for wood and plastic surfaces. Such pens do not fill the damaged area but are useful for color correction and hiding minor defects. For larger chips, it is advisable to first fill the area with a solvent-resistant plastic putty or filler, which should be sanded smooth after drying. Afterwards, the color can be touched up with a matching paint pen. Important: before application, the areas to be treated must be clean, dry, and free of grease to avoid adhesion problems. Sealing with a clear matte varnish can increase protection.
Palenar
1 Feb 2022 13:12
draleo schrieb:
For larger chips, it is recommended to first fill the area with a solvent-resistant plastic filler or putty, which can be sanded smooth after drying.
Building on that, especially with Besta furniture, which is often made from particleboard with a melamine laminate that is quite delicate. The filler should not only be solvent-resistant but ideally have some flexibility to prevent cracking due to temperature and humidity changes. I recommend a two-component plastic filler for furniture repairs, which fills chip-offs on edges and corners effectively.
The procedure would be:
- Lightly roughen the edges to improve adhesion
- Apply the filler sparingly and smooth it out with a small spatula
- After curing, gently sand with fine sandpaper (grit 320–400)
- Then touch up with a paint marker or acrylic paint in the matching color
Matching the color tone precisely is important—here, any color transition can be minimized by carefully dabbing and blending. If you are doing the repairs without workshop equipment, a melamine repair kit from a hardware store can also be useful; these are often enhanced for Ikea-style furniture.
KINMIN4
1 Feb 2022 18:47
I have had very good experiences with repair wax for small chips. You just need to warm the wax in the right color, press it into the damaged area, and remove any excess wax. After a short curing time, it becomes invisible.
Tinaneo
2 Feb 2022 07:39
That sounds appealing, but repair wax is not really durable on heavily used edges. Especially for furniture like Besta, which is frequently handled, wax can wear out or fall out relatively quickly.
A more permanent solution is usually a combination of filling and then applying paint or lacquer. This is the only way to achieve a stable and visually consistent repair. With wax, there is also the question of how well it replicates the appearance of the melamine coating – often you end up with a matte spot, while the furniture has a semi-gloss finish.
V
vin_leo
3 Feb 2022 11:51
Hey, I’ll chime in as well – I’d say when it comes to minor flaws on Besta, less is more! If you have a simple repair kit with colored markers or wax, try first to see if the shade matches. Sometimes a small repair is barely noticeable unless you know exactly where to look.
If that feels too fiddly, just use a touch-up paint pen in the right color and dab carefully. Don’t worry; in the end, this is usually better than leaving the spot untreated. And honestly – the most noticeable repairs happen when you try to do too much. So start with minimal effort and then decide if you want to fix it further. That’s how I did it, and the Besta still looks great 😄
